Results 1 to 13 of 13
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    Got a couple of them.
    OK I have a 2002 WS6 with full bolt ons and 3.73 gears. I was thinking of putting a high stall convertor with shift kit and cooler. How hard is it to install all of this? Does the car need to be tuned after the install? How much would this shave off the quarter? What shift kit, Trans go? I was thinking about a 3000 stall but what brand? And what cooler? I still need it streetable.
    Stalls usually knock about .5 off your ETs. Best mod for an auto there is.
    You can go up to 3500 stall and still be perfectly streetable. 3000 may not be big enough. If you plan to cam your car at some point, you want to pair up the stall and cam.
    If you are a DIY type, the labor is not really that hard, a day project. The cooler is very simple, the convertor isn't hard, but can be a PIA. Never done a shift kit myself.
    Trans Go is probably the best shift kit out there and you can pick up a cooler at your local parts store(thats what I did) or pick up a B&M cooler which is a very popular one as well.
    Tuning is highly recommended for a stall as well.
    Painted manta stripe
    Dalzell, Illinois
    2002 Trans Am WS6
    as of right now i plan on keeping the motor stock until the swap. I was going to do head and cam package but got a bike instead. Will I be able to drive the car to the shop to get it tuned?
    Quote Originally Posted by stephen02ws6 View Post
    Yes, it will run ok, shift points just need to be adjusted.
    Member MikeMoss's Avatar
    Kansas
    Rally Red
    2001 Camaro B4C
    I just put a 3000 stall in my car and kind of wish that I would have gone bigger. With a 3000 it drives basically the same as when it was stock.
    I have the transgo hd2 shift kit and it really was not that hard to install as long as you take your time, are careful, and follow the instructions.
    If you plan on doing everything yourself I would say you should probably put aside at least 2 days to do it. Drop the tranny and do the shift kit on day one, you should also do the corvette servo, and then put it back togather with the new torque converter on day 2.
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    I've been thinking about getting a stall very, very soon & then a cam in the future. Could you give a little more info in regards to pairing up the stall and cam?
    Georgia
    2014 Camaro 1LS
    I have yet to see any details on a stall install anywhere
    Kansas
    Rally Red
    2001 Camaro B4C
    http://www.bowlingss.com/LS1_How_To.htm
    In the transmission section.
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by MikeMoss View Post
    awesome link ! thank you sir
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    Quote Originally Posted by jujofields View Post
    for a mid range cam like a 224 or 228, 3000-3500 rpm stall is perfect.
    bigger cams, 3500-4000 rpm.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Quote Originally Posted by nhraformula View Post
    The man gives great advice
    South Carolina
    2000 Trans Am
    i have a 00 trans am..i gotta guy who is really good with installing performance stuff on anything and he really didnt want to mess the shift kit..they are pretty detailed and would def take at least a day, but i went with a B&M trans cooler too and it was easy to do. I have a 3.73 gear to put in, how difficult is that?? i hear its tough
    Dalzell, Illinois
    2002 Trans Am WS6
    Quote Originally Posted by MoNsTeR_LS1 View Post
    i had someone put the gears in. i didnt know how to do them so i someone else do it. i want to do the stall and shift kit to save on labor.
  1. Looking at a couple WS6's
    By WS6Doc in forum Firebird / WS6
    Last Post: 11-22-2011, 11:26 AM
  2. A couple ?s about RX8's
    By 01ls1ws6 in forum Almost Anything Goes
    Last Post: 04-20-2009, 02:10 AM
  3. Question: A couple of them
    By JoshieDoom in forum Firebird / WS6
    Last Post: 03-02-2008, 11:44 PM
  4. Couple of ? for you all.
    By transam98 in forum Internal Engine
    Last Post: 11-28-2007, 05:24 PM
  5. couple of ?'s
    By 2fast2blegal in forum General Help
    Last Post: 11-19-2007, 10:29 AM
