    Turnersville, NJ
    1999 Camaro Z28
    Installing intake manifold?
    I have a 99 Z28 with the LS1 intake manifold. I would like to upgrade to an LS6 intake manifold...with the EGR provision. What is involved in this swap? Are there any extra parts or gaskets I have to buy? How long has it taken most people? Thanks!
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    You can re-use the o-ring gaskets. Its not that hard, but be careful of the oil sending unit in the back of the block. Everyone seems to break them when taking the intake off.
    Leave the fuel rails and injectors on. Switch them after your get the intake out.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    Aug 2003
    Honolulu HI
    oh and it takes about 45minutes to an hour....the first few times
    Turnersville, NJ
    1999 Camaro Z28
    Do you think it is necessary to upgrade the throttle body when doing the manifold swap? Or should I just port the stock one?
    However, looking at the stock one....it does not look like there is much to port (my guess is: there wouldn't be much gains from it).
    Aug 2003
    Honolulu HI
    you dont have to. you could if you want. its not a high horsepower mod alone, but with everything else, it helps.
  1. Question: Installing new ZO6 intake w/injectors & MAF
    By SILVER BULLETT in forum External Engine
    Last Post: 08-30-2010, 06:15 AM
  2. LS6 intake manifold and 227 Intake runners
    By IT_SS in forum Internal Engine
    Last Post: 07-07-2009, 02:11 PM
  3. installing intake
    By david_viny in forum External Engine
    Last Post: 07-25-2008, 08:31 PM
  4. Soooo.... i was installing my intake
    By Z28_SS in forum External Engine
    Last Post: 02-29-2008, 02:58 AM
  5. installing intake right now?????`
    By sszcam in forum External Engine
    Last Post: 04-14-2007, 05:16 PM
