Results 1 to 13 of 13
    T/A is in Bahrain! 13nickels's Avatar
    Manama, Bahrain
    1998 Trans Am WS7
    OBX Headers and Eibach Sportlines
    OBX Headers, SPL Loudmouth and Eibach Sportlines with Bilsteen HD shocks is the combo, is anyone running this combo. Im looking for clearance issues. And has anyone tryed to flaten the pipes, is this possible. That may be a dumb ass question. I read the usual problems, potholes, driveways, speed bumps ect. I know its all part of having a low ride, but do the OBXs tuck under well and if not is it possible to bend them a little. If they touch the floor board is there a common material to put between the exhaust and floor to stop or minimize vibration?
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    I have the same headers and they tuck up very well. The y pipe on the other hand I got sick of it being loose, leaking from the band clamps, and hanging low, so I had a custom pipe made up and that works very well for me also. Lowering my car would not be much of a problem I dont think.
    Marylandistan
    2001 Trans Am (sold)
    I'd skip the OBX headers.
    Manama, Bahrain
    1998 Trans Am WS7
    Quote Originally Posted by INMY01TA View Post
    problem is i bought them already. Why do you say skip the OBX headers.
    Marylandistan
    Quote Originally Posted by 13nickels View Post
    I've read the primaries aren't even 1 and 3/4s. Among other things.
    Minnesota
    83 Z28 new project
    Mine are 1 3/4 primaries. My issue with these headers was that the left header was not bent right and had to dent in some to get the drain plug out, but others I guess have not had that prob.
    Member GNICTRY's Avatar
    Virginia
    2000 Trans Am WS6 Ram Air
    mine are fine but my steering rod bolt hit one of the pipes and needed a little grinding down but otherwise fit is perfect, make wise is great have no problem.
    not sure on lowering thou....i think ild be fine they look to have great clearance.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    I read that guy's post that said that. I have now seen 3 sets in person and they absolutely were NOT 1 and 1/2 like the ones he had a pic of, all of them are 1 and 3/4. I don't know how to tell before they are ordered, as the rest of his setup looks identical to the setups that I have seen, so that is something to consider.
    One of the sets was on Tiffany's (GNICTRY) car. That was actually the first set that I saw, and they made numbers on par with everyone else's LTs like Hooker, pacesetter, etc. Very nice for the coin spent.
    USA
    Velocity Yellow
    2008 Corvette Z06
    My OBX were as listed. Fit perfect and clearance is great. I even got the old kit that was missing all the parts needed for the install.
    2018 Tahoe - Silver - OEM
    Marylandistan
    Okay then cool. The drain plug issue was another. Was a problem with FLPs, these are the FLP design.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Just did my yearly oil change last week...the plug came off perfectly.
    Member MikeMoss's Avatar
    Kansas
    Rally Red
    2001 Camaro B4C
    mine had some fitments issues with the steering but that was easily fixed. My collectors sit higher then my oil pan does the whole exhaust is really tight against the floor when I first installed them they made lots of noise. And I had to put some heater hose in between the exhaust and the floor but it went away I was able to get all of it fixed.
    Bethlehem PA.
    1998 pontiac trans am
    i just put on my obx headers about a month ago....it went 10X easier then i thought it would...the only thing i had to do was take the oil filter off to get the drivers side up and in...no drain plug issues or anything like that...but it does make me wonder how someone can have problems and the next guy wont (the 1 1/2 primaries, drain plug,ect.)
  1. Eibach Sportlines
    By 94whtta in forum Parts For Sale / Trade
    Last Post: 06-11-2007, 11:03 AM
  2. Eibach Pro Kit or Sportlines??
    By ShadowHawk in forum Suspension and Handling
    Last Post: 04-17-2007, 05:19 PM
  3. New Eibach Sportlines 93-02
    By sercastiK in forum Western Members
    Last Post: 03-03-2007, 12:27 PM
  4. WTB Eibach Sportlines for 2002 Z
    By thelastz28 in forum Parts Wanted / Trade
    Last Post: 02-22-2007, 10:58 AM
  5. LT1 on Eibach Sportlines! (56k not so much)
    By guitarisawesome in forum Multimedia Section
    Last Post: 01-31-2007, 05:54 PM
