04-05-2008, 11:27 AM #1Junior Member
- Jun 2006
- Houston
- iTrader
- 0
Black- 02 WS6 TA
02 WS6 6 sp (build sheet incl in thread)
This has been my dream car but looking to start another project. Letting this one go for 26,500 obo. Check out the features below. Car has 65k miles and runs like a dream. Its Black on Black with no interior or exterior modifications (except a new head unit for the radio). I have never had the car on the drag strip and have never run the motor on Nitrous. The motor was set up for Nitrous as it was stroked without boring the cylinder walls. This achieved a 372ci displacement instead of the typical 382 but with full thickness on the cylinders walls you wouldnt have a problem running a 200 shot if you wanted to. If you look at the cam specs and head flow chart you can see that the motor is ready for it. I just never got around to it. The car pulled 465rwhp on the last dyno pull but that was through stock exhaust and you could tell she started to choke as the rpms came up. That prompted the exhaust work. Havent had it to the dyno since but I would be shocked if it didnt hit close to 500. The car is also set up for the street but you can tune the shocks for razor sharp handling. The car has been fitted with 315's on all 4 corners and will peel your face off through the turns. Road manners are great and it still gets good gas milage (thanks to the 6 speed). I use this as my daily driver and have done so since I purchased the car brand new in 02.
The car does have a couple minor issues. It has a ding on the rear quarter panel on the drivers side. I can have that fixed before you buy it. It also has a crack on the dash pad that you will have to fix if it buggs you. I still have alot of the stock parts but had to sell some of the larger parts to make room in the garage (i.e no stock rear end or exhaust).
Car was inspected last month and the title is clear. Im putting the car on LS1.com before putting it on Ebay because the people on LS1.com have been very cool and helped me with questions from time to time. I will keep it on here for a week before selling it anywhere else.
I have all reciepts (even the oil change reciepts when I had it done instead of doing it myself). I havent added them up but Im sure its alot....lol.
Email me at [email protected] with questions (Ill also send pics this way until I can figure out how to post).
Can someone tell me how to post pictures?
Heres the build sheet
Cam Specs:
Cam Motion
Custom Ground: Duration at .05
Intake and Exhaust Rocker Ratio = 1.7
Lobe Sep = 112.1
Valve Overlap = 9.5
Intake Exhaust
Valve Open 6.2 btdc Valve Open 51.5 bbdc
Centerline 109.9 atdc Centerline 113.9 btdc
Valve Close 46.6 atdc Valve close 3.4 atdc
Duration 232.8 cd Duration 234.9 cd
Lobe Lift .346 in Lobe lift .352 in
Valve Lift .588 in Valve lift .598 in
Lobe Area 28.24 in * deg Lobe area 28.77 in * deg
Heads Flow Chart
TEA Prepped 5.3L heads
Plus: Chrome Moly Retainers, Hollow stem (sodium filled) Valves, Isky Springs etc…
New set of valve springs at 63k miles
Lift EX INT
.100 49.5 67.8 11.25:1 compression ratio
.200 110.3 135.7 CNC porting including combustion chamber
.300 155.4 203.7
.400 220.6 249.2
.500 250.6 276.8
.550 260.2 291.7
.600 265.4 301.2
P2V clearance .070 .098 Head gasket thickness is .048
Engine Build Specs and Parts
by Scoggin Dickeys
LS1 Aluminum Block 3.90 Bore
Scat 4340 Forged Crank (stroke 3.90)
Manley 4340 Forged H-Beam Rods (6.125)
Forged Wiseco Flat Top Pistons (k366a05 with custom Pin dia & placement)
Wiseco Rings 39050gk (1.5mm, 1.5mm, 3.0mm, .014 gap, .20 gap)
Clevite Rod and Main Bearings
New GM Timing Chain set
Rear End
Mosier 12 Bolt built by Mosier but set up by Slaters in Houston in house with
Eaton Posi (800lb pre-load)
Mosier 33 spline axles
4:10 ratio
Additional Parts
New Head unit for the radio (SOny?)
Off-Road Y-pipe with O2 simms
Spec Stage III clutch w/carbon pads (replaced at 63k miles)
New lower control arms (boxed w/ poly bushings)
New Torque Arm (custom made adjustable Chrome Moly)
Poly tranny mount bushing and torque arm bushing (minimize deflection)
Custom Tuning by Motorsport Technologies Inc.
Low temp thermostat
Skip Shift Eliminator
Airbox Lid (free mod to lower air box)
K&N filter
Hooker Cat Back (switched to magnaflow muffler…still have the aerochamber)
Granetelli 85mm MAF
Power Stop cross drilled front rotors
Hawk HPS Brake Pads
Solid U-joint between driveshaft and rear end
Custom swaybar connection for rear
NGK Plugs
Taylor 8mm plug wires
Custom Weld in Sub Frame Connectors
Mac Midlength headers w/ y-pipe
Suspension
suspension recommendations from Strano and Kenny Bumberra
Koni SA adjustable front shocks
Bilstein 3rd gen rear shocks
35mm front sway bar
Coil over kit for the front (390 lb eibach springs)
Weight Jackers for the rear (170 lb eibach springs?)
Car lowered 1.8” as result (very little bottom dragging problems)
Custom Adjustable Aircraft Aluminum panhard rod with hymes ends
Bumberras racing front end alignment (1 degrees neg camber)
Corner weighted to achieve 49.5% cross weight! at 3450 lbs
17 x 11 Black Corvette Wheels on all 4 Corners
Ground steering knuckle to accommodate
¼” spacer used for the fronts
Current Tire is Sumitumo HTRZ 315R35/17
Last Dyno at 465 (RWHP) without headers installed.
04-05-2008, 11:58 AM #2Member
- Apr 2006
- Lafayette, Indiana
- iTrader
- 0
Pewter Metallic- 2002 Trans Am WS.6
That's a pretty mean setup you've got there! What are you asking for it? In regards to how to post pics, simply create an account at www.photobucket.com (it's free to do so). Upload your pics onto your photobucket account & then copy & paste the IMG URL into a message on here. If you have any other questions while trying to post pics, just send me a message!
04-05-2008, 01:44 PM #3Junior Member
- Jun 2006
- Houston
- iTrader
- 0
Black- 02 WS6 TA
images
ok here are the pics I already had. I will shoot some better pics when weather permits.
04-05-2008, 01:45 PM #4Junior Member
- Jun 2006
- Houston
- iTrader
- 0
Black- 02 WS6 TA
04-05-2008, 04:14 PM #5
04-08-2008, 09:06 AM #6Junior Member
- Jun 2006
- Houston
- iTrader
- 0
Black- 02 WS6 TA
anyone interested at 25k?
Question: Build sheet?
By lownloud99 in forum Firebird / WS6Replies: 3Last Post: 01-03-2014, 12:23 PM -
Build Sheet
By SMWS6TA in forum Firebird / WS6Replies: 9Last Post: 07-14-2010, 10:45 AM -
Finally got the 3rd gen dynoed (Dyno sheet incl)
By 86 IROC-Z in forum Almost Anything GoesReplies: 22Last Post: 09-27-2009, 07:44 PM -
My Build Sheet.
By speedracer25f in forum Firebird / WS6Replies: 2Last Post: 11-05-2007, 01:41 PM -
Build Sheet?
By ws4transam in forum GTOReplies: 4Last Post: 02-11-2006, 12:27 PM
