12-12-2005, 09:30 PM #1
Swaybars as my first suspension mod
Hey everybody, I know that if you do some upgrades alone without others to compliment it, then it can hurt your suspension rather than help it.
I'm planning on throwing on a couple sway bars 35mm front and 25 rear. My question is: If I do these on my otherwise stock suspension, would it be good?
Thanks a lot guys!
12-13-2005, 02:23 AM #2
First suspension mod should be shocks - I have Custom Revalved HD Billsteins from Strano.
If you are going with sway bars - don't go any bigger than 21mm for the rear bar. I thought that 'bigger was better, and went with a 25mm rear - car was very loose in the rear. After talking with Sam @ Strano he stated not to go with anything bigger than 21mm.
Give him a call - very knowledgeable about anything suspension related. He actually sells the sway bars that were custom made for Strano that are hollow - save yourself some weight
-Jay-
12-13-2005, 04:42 AM #3Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Sub frame connectors first.
12-13-2005, 10:34 AM #4
Damn, I'm confused again
I may end up just buying a package and then putting it all on at one time. This is going to sound retarded but I'm trying to put ZL-1 parts on my camaro hoping to have a lot of its characteristics, know what I mean?
Why would the 25mm in the rear make it more loose? I want the whole car tight as hell.
12-13-2005, 01:00 PM #5
If you're talking chassis modes - then I WOULD go with the SFC's first - they will really stiffen up the car, then STB, then LCA's, Panhard Bar, Torque Arm with poly bushings.
If you're talking suspension - then go with shocks first, and if you're doing springs - do them after the shocks.
As far as the reason why the car is loose with 25mm bar - I'm not the suspension expert - Sam Strano IS. I installed the 25mm rear bar before going to him at all - when I complained about how the car handled loose in the twisties he asked what size rear bar I put in - when I told him the 25, he stated that was the problem - too big on the rears of our cars. Once I switched to 21mm, everything was great
So if you want a technical answere I would tell you again to talk with Sam. He wasn't the SCCA Champion in his LS1 Camaro a couple years for nothing.
12-13-2005, 01:56 PM #6
cool.
The set up I want for my camaro is mainly for something like autocross. I want it hooking great when I stomp the gas too. Maybe the zl1 is mostly a drag car. I may endup getting all the parts I need for my total suspension upgrade then I'll put them on. I'll keep in mind sam at strano. Thanks
Question: What does removing swaybars do
By Eganslp in forum Suspension and HandlingReplies: 29Last Post: 12-06-2010, 02:21 AM -
FS 04 Swaybars and end links
By BitViper in forum CorvetteReplies: 0Last Post: 09-23-2008, 08:47 AM -
Strano Swaybars
By Sam Strano in forum Suspension and HandlingReplies: 1Last Post: 08-04-2008, 11:25 PM -
BMR Swaybars Front and rear
By RS_SS69 in forum Parts For Sale / TradeReplies: 1Last Post: 07-12-2008, 10:39 AM -
factory swaybars
By motrhd1 in forum Parts Wanted / TradeReplies: 3Last Post: 07-29-2007, 03:02 PM
