Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    Member 35thLS1's Avatar
    Oct 2001
    Carlsbad, CA. (San Diego)
    Custom
    2002 LS1
    some cool facts if you have nothing to do!!!
    Cool Facts
    - Barbie's full name is Barbara Milicent Roberts.
    - It is impossible to lick your elbow.
    - A crocodile can't stick its tongue out.
    - A shrimp's heart is in their head.
    - People say "God Bless you" when you sneeze because when you sneeze, you're heart stops for a mili-second.
    - In a study of 200,000 ostriches over a period of 80 years, no one reported a single case where an ostrich buried its head in the sand (or attempted to do so).
    - It is physically impossible for pigs to look up into the sky.
    - A pregnant goldfish is called a twit.
    - Between 1937 and 1945 Heinz produced a version of Alphabetti Spaghetti especially for the German market that consisted solely of little pasta swastikas.
    - By law, every child in Belgium must take harmonica lessons at Primary school.
    - On average, a human being will have sex more than 3,000 times and spend two weeks kissing in their lifetime.
    - More than 50% of the people in the world have never made or received a telephone call.
    - Rats and horses can't vomit.
    - The "sixth sick sheik's sixth sheep's sick" is said to be the toughest tongue twister in the English language.
    - If you sneeze too hard, you can fracture a rib. If you try to suppress a sneeze, you can rupture a blood vessel in your head or neck and die.
    - Rats multiply so quickly that in 18 months, two rats could have over a million descendants.
    - Wearing headphones for just an hour will increase the bacteria in your ear by 700 times.
    - If the government has no knowledge of aliens, then why does Title 14, Section 1211 of the Code of Federal Regulations, implemented on July 16, 1969, make it illegal for U.S. citizens to have any contact with extraterrestrials or their vehicles?
    - In every episode of Seinfeld there is a Superman somewhere.
    - The cigarette lighter was invented before the match.
    - Thirty-five percent of the people who use personal ads for dating are already married.
    - A duck's quack doesn't echo anywhere, and no one knows why.
    - 23% of all photocopier faults worldwide are caused by people sitting on them and photocopying their buttocks.
    - In the course of an average lifetime you will, while sleeping, eat 70 assorted insects and 10 spiders.
    - Most lipstick contains fish scales.
    - Cat's urine glows under a black light.
    - Like fingerprints, everyone's tongue print is different.
    - If you keep your eyes open by force, they will pop out.
    Minnesota
    '10 ZR1
    I've got some better shit than that! Check these out:
    * One Top Fuel dragster 500 cubic-inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.
    * Under full throttle, a dragster engine consumes 11.2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
    * A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
    * With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
    * At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7,050° F.
    * Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
    * Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
    * Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1,400° F. The engine can only be shut down by cutting the fuel flow.
    * If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
    * Dragsters reach over 300 MPH before you have completed reading this sentence.
    * In order to exceed 300 MPH in 4.5 seconds, dragsters must accelerate an average of over 4 G's. In order to reach 200 MPH well before half-track, the launch acceleration approaches 8 G's.
    * Top Fuel engines turn approximately 540 revolutions from light to light!
    * Including the burnout, the engine must only survive 900
    revolutions under load.
    * The redline is actually quite high at 8,400 RPM.
    * THE BOTTOM LINE: Assuming all the equipment is paid off, the crew worked for free, & for once, NOTHING BLOWS UP, each run costs an estimated $1,000 per second.
    The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter-mile (10/05/03, Tony Schumacher). The top speed record is 333.00 MPH (533 km/h) as measured over the last 66' of the run (09/28/03, Doug Kalitta).
    Putting this all into perspective:
    You are driving the average $140,000 Lingenfelter twin-turbo powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged & ready to launch down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH. The 'tree' goes green for both of you at that moment.
    The dragster launches & starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums & within 3 seconds, the dragster catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it - from a standing start, the dragster had spotted you 200 MPH & not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race!
    That's acceleration!
    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    I Love Dragsters!
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    If you supress a sneeze, a burp, & a fart at the same time you will explode
    Member krese's Avatar
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    Quote Originally Posted by 35thLS1 View Post
    Cool Facts
    not all are facts.... interesting list though
    Member C&Cbird's Avatar
    Oklahoma City, Oklahoma
    The redline isn't that high anymore on the Top Fuel cars, NHRA has them limited to 8,400 I believe.
    Minnesota
    '10 ZR1
    Quote Originally Posted by C&Cbird View Post
    Fixed
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    both cool reads!
    West Cheter, PA
    '98 Black Gone :(
    01 WS6 Midnight Blue
    there are fish scales in my lip stick!?!?!? GROSS!!!!!!!!!!!
    Quote Originally Posted by ls1blackbeauty98 View Post
    and fish anus in your tooth paste...
    Beer Pong Champ Nitro_Junkie97's Avatar
    Feb 2008
    White and Orange
    1997 Z/28
    ha. as long as it keeps my tooth clean.
    Quote Originally Posted by Nitro_Junkie97 View Post
    i made that one up...
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Hey girl, you got FISH LIPS!
    BTW: To be honest, this was nicer than the other thing I was planning on posting....
    Denton (Dallas)
    2003 GTI 1.8T :(
    those facts are cool
    Quote Originally Posted by 67CamaroRSSS View Post
    damn it... now you got to tell!!!!
    Denton (Dallas)
    2003 GTI 1.8T :(
    coughdicklipscough
    im not saying that... just saying what i think he was going to say
    Feb 2008
    White and Orange
    1997 Z/28
    damnit.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Wellll, it had to do with the femine gender and the smell of fish........
    Although sperm burping would have worked as well.
    BLACK DOESN'T WORK!!! DEZI425's Avatar
    Charlotte NC
    05 Ducati 999
    06 Mazdaspeed6
    Quote Originally Posted by FasstChevys View Post
    That is Awesome!
    nj
    90 Mustang 5.0
    Cool Facts
    MORE! that shit is interesting.
  1. Good facts please
    By odinsonthor in forum Almost Anything Goes
    Last Post: 09-25-2010, 08:06 PM
  2. Georgia - Just The Facts And The Truth
    By SLIM_DURST in forum Political / Debate Forum
    Last Post: 08-12-2008, 07:36 AM
  3. Chuck Norris Facts!
    By Musclefan21 in forum Almost Anything Goes
    Last Post: 02-08-2008, 01:45 PM
  4. Mr T facts
    By Nastyfoot in forum Almost Anything Goes
    Last Post: 12-10-2006, 05:50 PM
  5. facts to ponder
    By Zboner in forum Almost Anything Goes
    Last Post: 03-28-2006, 11:10 PM
