Results 1 to 16 of 16
Thread: 2000 WS6 Low Miles, Many mods!
03-30-2008, 02:03 PM #1Member
- Indianapolis, IN
- iTrader
- 2 (100%)
Silver- 2002 Trans Am WS6
This Trans Am WS6 was built to be a powerhouse on the street or on the strip. The motor was professionally rebuilt less than 50 miles ago. Before the rebuild, it made 414 horsepower and 381 ft-lbs of torque at the rear wheels as you can see on the dyno sheet. The car is navy blue with black leather interior with a 6-speed manual transmission. The car only has 31,309 miles! There are way too many modifications to mention, so here are most of them:
Engine
Ported LS6 heads w/ 5 angle valve job and dual valve springs
TSP Torquer camshaft: 232/234, .595"/.598" 112LSA
TSP modified LS6 oil pump
TSP Chromoly 7.40" pushrods
Ram Automotive billet steel flywheel
Ram Automotive adjustable master cylinder
Ram Automotive powergrip stage 3 clutch
Rollermaster double roller timing set
Ford Racing 30lb fuel injectors
MSD 8.5mm spark plug wires
NGK spark plugs
Dynatech SuperMAXX headers
Corsa quad-tip exhaust
Custom built off-road Y-pipe with cutouts
Suspension, Rear End, Brakes, Tires
UMI rear lower control arms
Random Technology torque arm
Ford 9" rear end with locker
Nitto drag radials with excellent tread
2-piece cross drilled/slotted front rotors, wagner pads all around
Interior
Sparco racing seats
Roll cage
Granatelli 200 MPH white speedo
Boston Accoustic component speakers
Please note that the stereo does work (I tested it in another car), however, the speakers are not connected to the factory stereo wiring, as they are aftermarket speakers and at one point there was a complete stereo system in the car. The car is in great shape, although there are some scratches on the paint and a few imperfections in the interior. Definately a '20 footer'. This is not a show car, it could a great street/strip racer or by changing the seats and differential, would be a decent daily driver. Included are the rear plastic fender covers that cannot be installed with the roll cage, along with other misc. parts.
Also, I have a brand new BMR adjustable panhard rod in my garage. It is available for an additional $200 installed.
I will post pics shortly.
Asking $16,500 obo. I live in central Indiana, and can trailer the vehicle a few hundred miles for a minimal fee.Last edited by rbrack; 04-20-2008 at 02:34 PM.
03-30-2008, 02:23 PM #2Member
- Indianapolis, IN
- iTrader
- 2 (100%)
These are high res pictures, so they will take a few minutes to load:
http://monkey-home.is-a-geek.com/tapics/ta1.jpg
http://monkey-home.is-a-geek.com/tapics/ta2.jpg
http://monkey-home.is-a-geek.com/tapics/ta3.jpg
http://monkey-home.is-a-geek.com/tapics/ta4.jpg
http://monkey-home.is-a-geek.com/tapics/ta5.jpg
http://monkey-home.is-a-geek.com/tapics/ta6.jpg
http://monkey-home.is-a-geek.com/tapics/ta7.jpg
http://monkey-home.is-a-geek.com/tapics/ta8.jpg
http://monkey-home.is-a-geek.com/tapics/ta9.jpg
http://monkey-home.is-a-geek.com/tapics/ta10.jpg
http://monkey-home.is-a-geek.com/tapics/ta11.jpg
http://monkey-home.is-a-geek.com/tapics/ta12.jpg
http://monkey-home.is-a-geek.com/tapics/ta13.jpg
http://monkey-home.is-a-geek.com/tapics/ta14.jpg
http://monkey-home.is-a-geek.com/tapics/ta15.jpg
http://monkey-home.is-a-geek.com/tapics/ta16.jpg
http://monkey-home.is-a-geek.com/tapics/ta17.jpg
http://monkey-home.is-a-geek.com/tapics/ta18.jpg
http://monkey-home.is-a-geek.com/tapics/ta19.jpgLast edited by rbrack; 03-31-2008 at 05:55 PM.
03-31-2008, 06:00 PM #3Member
- Indianapolis, IN
- iTrader
- 2 (100%)
Updated the pics. Also forgot to mention the mileage, it is 31,309 miles on the chassis, less than 50 on the motor.
04-06-2008, 05:34 PM #4Member
- Indianapolis, IN
- iTrader
- 2 (100%)
ttt
Please make an offer, I need to get rid of the car.
04-06-2008, 05:39 PM #5Member
- Jul 2007
- tazewell, tennessee
- iTrader
- 0
red- 1999 Trans Am WS-6
any idea what the car dynos at now
04-06-2008, 06:16 PM #6Member
- Indianapolis, IN
- iTrader
- 2 (100%)
Other than the rebuild parts (rings, bearings, gaskets, etc.), the motor has the same parts as the last dyno. It should dyno the same or slightly better, but it can't be dynoed again until after the motor is broken in.
04-14-2008, 03:14 PM #7Member
- Indianapolis, IN
- iTrader
- 2 (100%)
Price lowered!!
04-20-2008, 02:26 PM #8Member
- Indianapolis, IN
- iTrader
- 2 (100%)
ttt
04-30-2008, 09:08 AM #9
What are the rear gears, compression ratio, do you still have the factory seats, why was the engine just rebuilt 50 miles ago and while are you selling? Subframe connectors? Is the roll cage removable?
04-30-2008, 10:07 AM #10Member
- Indianapolis, IN
- iTrader
- 2 (100%)
The rear gears are 4:11, compression ratio is stock, I don't have the factory seats but you can sell the Sparco seats for more than you can buy factory seats. The engine was rebuilt because it have rod bearing go out. No subframe connectors. The roll cage is bolt-in, so it can be removed fairly easily.
04-30-2008, 11:15 AM #11King 0f n00bz
- Jan 2006
- Shepherd, Michigan
- iTrader
- 1 (100%)
dammmn! i wish i had the money my man..i'd buy that in a heart beat.
04-30-2008, 05:21 PM #12
Do you have receipts for the major mod's? Who installed the parts?
05-14-2008, 03:15 PM #13
do you still have the car?
05-16-2008, 07:43 AM #14Member
- Indianapolis, IN
- iTrader
- 2 (100%)
I do still have the car, and I am willing to take $15,000 for it before my ebay auction ends tomorrow night, which is much less than I have invested in the car. I have most of the receipts, including the rebuild kit, heads, cam, clutch, and several others. The motor was removed, completely stripped, and rebuilt by a friend of mine who is an ASE certified mechanic at a local car dealership. Please email me at [email protected] or call me 317-213-5430 ASAP if interested.
05-20-2008, 09:35 AM #15Junior Member
- May 2008
- beatrice ne
- iTrader
- 0
black- 2002 2500 HD
i have a 02chevy 2500HD ext cab 4x4 w 6"procomp lift,new shocks front and back,front hoops,new 35x12.50x20 nitto muddgrapplers w 20"moto metal rims. duel flowmaster,superchip,full k&n intake and filter,subs,mids,highs,duel amps,touchscreen indash dvd,navigation.
FOR SALE at $18,000 or TRADE straight across. my email is [email protected] u can view the truck at www.whiteboystoys.com go to search then type in beatrice ne.
05-23-2008, 04:46 AM #16
why are you selling it after you just had the engine rebuilt?
2000 Camaro SS (low miles w/mods)
By cmb570 in forum Vehicles For Sale / TradeReplies: 25Last Post: 11-03-2009, 06:34 PM -
For Sale: 2002 WS6, M6, low miles, few mods
By misterfnygy in forum Vehicles For Sale / TradeReplies: 0Last Post: 06-07-2009, 09:07 AM -
$2000 on suspension mods or on motor mods??
By greatwhiteZ28 in forum Suspension and HandlingReplies: 6Last Post: 09-27-2007, 06:04 AM -
2000 Camaro Z28 (low miles, few mods.) located in 45895
By jarid02 in forum Vehicles For Sale / TradeReplies: 0Last Post: 08-11-2006, 09:22 AM -
2000 ws.6 with mods; 93k miles; FS $13,000
By third_shift|studios in forum Vehicles For Sale / TradeReplies: 10Last Post: 10-12-2005, 02:37 PM
