Results 1 to 20 of 22
    Face Man Patsy57's Avatar
    Dirty Jersey
    2002 WS6 TA
    Where to Purchase o2 Sims and will it relieve issu
    Where can I get o2 simms? Also when my inspection failed they said that the catalyst monitor and secondary air were not ready will this help eliminate this? I have long tube headers going to dynatech powercats and then to a borla catback.
    calif.
    It usually takes 3-4 drive cycles to set the readiness monitores to "ready"So the car must completely cool down--and start cold and run normally 3-4 times--Every time you interupt the computer by just reading the codes--it re-sets the monitor and you have start all over again with the drive cycles--
    Now if you removed the cats or replaced them with aftermarket ones--it may never set the monitor for the catalyst system to ready--beacuse the readings will never be the same as stock--To fix that--you must delete the codes for the catalyst system by setting the enablers to "not reported"
    Dirty Jersey
    2002 WS6 TA
    Quote Originally Posted by tblu92 View Post
    What device should I use to do that? Predator?
    calif.
    Not toataly familiar with the Predator- but usually it takes a full programmer like HP Tuners or EFILIVE to remove DTC code enablers
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by Patsy57 View Post
    o2 simms were outlawed by the EPA. Casper Electronics got fined over $1 million dollars.
    mercersburg pa
    hugger orange
    2004
    I'm having the same problem with my 04 gto. I found a site that shows you how to make your own simulators with parts from radioshack for like $5. or you can buy sims for around $50 plus shipping..... if you can wait till next week o am going to radioshack this morning when I get off to buy the parts(a few resistors and a capacitor) . friday I'm wiring it up and installing it. if it works the way it is supposed to I will let you know.
    let the F-Bodies roll jimmybling31's Avatar
    hixson tennessee
    94 camaro z28
    you're joking? I hate the epa. always ruiningn everything. they are saying that the emmissions in my area are too bad. It's not the cars, because we have a sniffer with computer test for 96up and sniffer for earlier. It pisses me off that they are trying to make this a california type area. it'll piss off alot of people being in the south and being that there are people that have had lt's with no egr or anything for years and them changing to a california system would take 40% of the modified cars off the road and in the south modding is pretty big.
    Dirty Jersey
    2002 WS6 TA
    Quote Originally Posted by mark21742 View Post
    Please let me know how they work out and also where the document is showing how to build the units. Thanks!
    Member TedsB4Csled's Avatar
    Feb 2008
    Asheville, NC
    2002 B4C
    Will deleting rear O2 sensors allow you to pass emissions still? If not what is the point?
    orlando, fl
    2014 camaro 2ss/rs
    not kidding. there's threads from last year about it. having rear o2 simms keeps the CEL from coming on reporting the bad cat and rear o2 codes from coming on. i used to have them. by watching the scanner, it kept rotating the numbers around. something like 440, 665, and 850 over and over.
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by TedsB4Csled View Post
    a PCM scan emmission test, you will pass. a visual, no.
    Feb 2008
    Asheville, NC
    2002 B4C
    So keeping 02 sensors & gutted cats then delete 02 with a tune would be ok?
    Feb 2008
    Asheville, NC
    2002 B4C
    Hypothetically of course...
    orlando, fl
    2014 camaro 2ss/rs
    yes
    Feb 2008
    Asheville, NC
    2002 B4C
    You sleep as much as I do Thanks.
    mercersburg pa
    hugger orange
    2004
    I got all the parts, (two radio shacks and an electronics store later), haven't slept since yeserday afternoon, so I'm gonna get some sleep and wire them first thing in the morning! (with PC board, and neat little sealed box included in price) i'm set back about $15...... wish me luck!!
    Feb 2008
    Asheville, NC
    2002 B4C
    You have a link to the site, how to make O2 sims?
    mercersburg pa
    hugger orange
    2004
    United States
    Honda MDX
    dfdfgdfgdfg
  1. WTB 02 Sims
    By CamaroFan71 in forum Parts Wanted / Trade
    Last Post: 08-20-2008, 08:20 AM
  2. 02 sims
    By CamaroFan71 in forum General Help
    Last Post: 07-29-2008, 06:29 AM
  3. !help! What o2 sims to purchase?
    By RDS in forum External Engine
    Last Post: 10-28-2006, 10:53 AM
  4. ok, been looking an hour, HELP! need a link to purchase 02 sims!
    By Huntaholic in forum Computer & Tuning
    Last Post: 06-18-2006, 05:40 PM
