Page 1 of 3 123 LastLast
Results 1 to 20 of 57
    T/A Everyday oreowizard's Avatar
    Charlotte, NC
    blue
    98 T/A LS-1
    Whats the deal with "Piston Slap"?
    had the motor back together for a few months now and on a cold start there is a knocking sound. When the temp comes up the sound goes away? Sometimes under hard acceleration I can hear what seems to be the same sound. Any help?
    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    just how it is man... its because they heat the block up to a certain degree soo when the motor is cold the piston isn't fully seated
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    x2 the problem was solved with ls2+ engines..they switched to a floating pin design for the heads. that is why its pivotal for ls1 owners to let their car's warm up to op. temp before they drive them
    Charlotte, NC
    blue
    98 T/A LS-1
    Will it hurt them if we dont let them warm up. No jumping in them and going?
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by oreowizard View Post
    well it creates extra wear.
    The Demon Demon_Z28's Avatar
    Feb 2008
    WA
    Bright Rally Red
    ive never had the problem, I know I have a sticky vavle, buts its been like that since day 1.
    Aug 2000
    Indy
    welcome to the slapper
    Member 2-bowties&abird's Avatar
    Jan 2008
    lancaster,va.
    cam/lt headers
    blue 2000 ws6 m6
    5.3's did it too. i wouldnt worry, almost 140,000 on my 99 z71 with no problems what so ever.
    demonz28 is one of the lucky ones, i have heard a few people say their's doesn't do it, but 9 out of 10 do.
    Charlotte, NC
    blue
    98 T/A LS-1
    well then Im gonna drive on!!! Still looking for a '02 SS M6 to make a monster out of or a WS6.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Yes, it's quite common on many LS1s. Fortunately, mine has never had it.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Mine doesnt do it often. Just when its really cold or i havent started the car in a couple of days...
    Sounds like a exhaust leak
    Georgia
    2014 Camaro 1LS
    mine does it but with a new oil change its pretty quiet
    Retired Outlaw Sum Bitch
    Piston Slap is caused by the piston skirts being too short and allowing the piston to rock in the cylinder. Doesn't hurt anything but sounds like hell. It goes away not when the engine warms up but when the oil film builds up enough to cushion the "slap" of the piston skirt against the side of the cylinder wall.
    Shepherd, Michigan
    98' trans am
    ahh see i heard that too. i thought it was the pin design on the ls1 heads that caused the issue
    Member danziger's Avatar
    Aug 2006
    Chesapeake, VA
    Le Mans Blue
    2004 Z16
    Sarge is correct. The short skirt and pin placement cause the piston to rock, "slapping" against the cylinder wall. As the piston warms it expands (as does the cylinder) and stabilizes. Now if your engine makes noises ouside of the normal noisy valvetrain when warmed up, there may be an issue.
    Marylandistan
    2001 Trans Am (sold)
    This is a myth.
    Feb 2006
    MD
    Quote Originally Posted by INMY01TA View Post
    This is a myth.
    You're in Crofton right? If you feel like stopping by the Severn area sometime I'll disprove your comment You can actually see where the #1 piston was rocking in the bore, wearing the liner. Not coincidentally, all my piston slap noise in that engine was traced to the #1 or #3 cylinder with a stethoscope.
    To the OP, if you still hear the same noise when warmed up during acceleration, you may have more than just piston slap. A damaged oil pump pickup o-ring will cause oil aeration and cause a VERY similar noise. GM issued a TSB for this.
    Jan 2008
    lancaster,va.
    cam/lt headers
    blue 2000 ws6 m6
    Quote Originally Posted by Marc 85Z28 View Post
    with how many miles on the motor?
    Feb 2006
    MD
    Quote Originally Posted by 2-bowties&abird View Post
    It was pulled at 38K. It had one of the worst cases of piston slap I've ever heard. I put in another shortblock (60K miles) and it has absolutely no piston slap at all. Oddly enough, the cylinder liners looked perfect.
    Jan 2008
    lancaster,va.
    cam/lt headers
    blue 2000 ws6 m6
    wow, i was expecting you to say like close to 200,000 miles or something.
  1. Bottom Dropping Out on Public Support for Obama/Iran "Deal"
    Last Post: 09-18-2015, 09:00 AM
  2. Hussein Obama: Opponents to Iran "Deal" are "Crazies"...
    Last Post: 08-26-2015, 11:11 AM
  3. Jessie Jackson Jr. Plea Deal: "Significant Jail Time"...
    Last Post: 02-07-2013, 07:48 PM
  4. My piston slap oil findings. Whats yours?
    By transamdave in forum Firebird / WS6
    Last Post: 12-24-2012, 07:32 AM
  5. Replies: 13
    Last Post: 10-25-2007, 04:43 PM
