Results 1 to 14 of 14
Thread: Rear brake rotor install
03-24-2008, 11:55 AM #1
Hi guys I am changing my rear rotors and pads as I write this. I had just done my fronts all went well fairly quick and easy. I was going off the install university guide. It looks like that guide only really applies to the front. My rears seem to have what appears to be a lock washer over three of the studs on each side of the rear. Is this stock? Has anyone here changed their rear rotors and might be able to guide me a bit? I just need to get the rear rotors off and then I can pretty much take it from there.
03-24-2008, 12:29 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
If I remember correctly when I swapped my rear only one lug had a "star" washer on each side, didn't bother to put them back on.
03-24-2008, 12:37 PM #3
I have 3 on each side. I pry'd them off using a thick paint scraper. Then lightly hammered the back of the rotor until it started to give way. Closing up the rear left now. Should be all done soon. I assume they were just to hold the rotor in place while putting the caliper on. Thanks for the info, I am gonna check with a gm dealership to see if there is a reason they should be on or what not. I am sure I will get a blank stare when I ask. Maybe one of the vet's will see this on here and have an idea later.
03-24-2008, 05:32 PM #4
My 2000 had 3 on each side. My understanding of the need for those washers is mainly an assembly aid. Through the factory, those washers hold the rotor on until wheels are installed. The suspension is done much ahead of actually bolting on wheels. So once the car is yours, there isn't much need for those washers.
03-24-2008, 07:07 PM #5
Ok thanks that is basically what I was thinking, I will post some pics of the finished install most likely tonight. I went with the ebc zinc washed dimpled and slotted with red stuff pads. Going through the whole seasoning portion now. I have about 190 miles on the front rotors and 30 on the rears.
03-24-2008, 07:51 PM #6
03-24-2008, 07:57 PM #7
I have alot more pics on my myspace if you want to see them or have any questions pm me. The caliper work will be coming on the next warm weekend.
03-25-2008, 05:57 AM #8
03-25-2008, 06:13 AM #9
03-25-2008, 12:18 PM #10
03-26-2008, 07:18 AM #11
Your right I should and will do that now and I basically hacked them off with a thick paint scrapper and hammer
. So they won't be going back on anyway
03-26-2008, 07:21 AM #12
03-26-2008, 07:28 AM #13Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
I just used a flat head screwdriver placed the tip on one of the ridges and smacked it lightly with my hand. Once they are loosened up you can spin them off like a nut.
As said above just something the factory uses to help with assembly. I would throw them out so you have one less thing to deal with whenever you want to work on the brakes.
I also suggest use locktite on all the brake caliber bolts. Torqued mine up and went for a test drive. One of the bracket bolts for the rear fell of and bound up with the rim.
03-26-2008, 07:37 AM #14
I did use locktite and torqued everything to the correct specs. I rechecked the front lugs when I was closing up the rears because I did them 2 days before. a couple had gone back quite a ways. Probably those few 100+ mph runs didn't help. The frame and caliper bolts themselves seem to be solid.
Brake rotor rubbing
By 98RedTA in forum General HelpReplies: 5Last Post: 04-22-2014, 06:08 PM -
Help: Rear Brake Rotor
By Black Dragon WS6 in forum General HelpReplies: 3Last Post: 06-20-2009, 10:47 AM -
Project C5X Baer Brake Rotor Install - Braking New
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 01-06-2009, 11:50 PM -
Rotor and brake help!
By NJ2002WS.6 in forum Firebird / WS6Replies: 33Last Post: 09-13-2008, 04:30 AM -
brake pad and rotor upgrade????
By clg82 in forum Suspension and HandlingReplies: 18Last Post: 05-04-2007, 10:40 PM
