Results 1 to 11 of 11
03-23-2008, 06:31 PM #1
fuel pump install, how long for a garage?
How long an operation is it to replace the fuel pump and filter in a 96 lt1 trans am?
03-23-2008, 07:34 PM #2
I don't know, but I know it can get involved. Unless you take the short cut and cut a hole in the trunk to get to the fuel pump, it takes some time. Without cutting anything, you have to drop the rear, then drop the tank to get to the fuel pump I think. So, how ever long that takes...
03-23-2008, 10:47 PM #3
really does not take very long if you go through the trunk, if you search you will find a write up on it.
03-24-2008, 01:49 AM #4
A shop isnt going to go through the floor. That would be an insanely huge liability for them. Not going to happen.
My guess on their billing hours... ~4-7
03-24-2008, 05:24 AM #5
i cut a hole and had it done in 1 hour
03-24-2008, 02:36 PM #6
fuck it they can cut whatever they want if it saves 5 hours of labor... ill just list it as a weight saving mod if i ever sell ha
03-25-2008, 05:15 PM #7
Do it right and drop the tank.
I've done a few,,,,it's not that bad,,,sheeeesh. Cutting holes in the floor for a fuel pump is like cutting a hole in the hood to check the oil because I was too lazy to lift the hood up.
Someone with a car lift and a tranny jack can make short work of this. I do them in a couple hours.
You don't have to drop the entire rearend out of the car,,,,,I simply remove the lower shock bolts and pan hard bar and let the rearend lower down,,,this has always given me enough room.
Some people make this out to be worse than it really is.
03-25-2008, 07:09 PM #8
04-15-2008, 08:08 PM #9
-1 lol
i cut into mine... its in an area that is covered by a mat and then another piece of carpet... it doesnt do any major damage to the structure of the car... it can be easily and cleanly sealed up... and it saves a lot of time, and time is money... but its nowhere like cutting a hole in the hood to check the oil lol... it would be best described as not walking over to the tool chest to dig through to find the correct size wrench, and instead taking it off with a pair of channel locks that are sitting right beside you to save the hassle and time... thats my take on it anyway
04-16-2008, 02:00 AM #10
Wow, you must be a GM chassis engineer to know it doesnt do anything to hurt the structure of the car. In actuality... if you had a bad enough wreck, it most likely would be a weak spot, and could be a place for fuel to leak into the interior of the car. What are the odds of that happening... probably not all that great, but still.. cutting a hole is just being lazy.
04-16-2008, 03:50 AM #11
Eeeeew,,,,channel locks instead of the correct wrench????? Guess you are used to rounding bolts off?????
Just do it right. When I buy a 3rd or 4th gen one of the things I do is pull the carpet back to look for that dreaded hole cut into the floor. I pass on those cars. Just tells me how the owner treated the car and I start wondering what other corners he cut while performing repairs,,,,that type of mentality on repairing cars is one reason there are some scary/unsafe cars on the road today
Before you go chopping the car,,,bring it over to my shop. I generally change these for people for less than $100 and you can have your car back in a couple hours with all it's original sheet metal intact
Fuel pump install
By Danger731 in forum Western MembersReplies: 9Last Post: 12-13-2009, 10:30 PM -
Fuel pump install
By Badass99SS in forum General HelpReplies: 0Last Post: 11-20-2007, 10:13 AM -
How long for garage to install bolt in ypipe?
By grandkodiak in forum LT1Replies: 2Last Post: 08-13-2007, 10:18 PM -
How much to install a new fuel pump in 98 t/a
By I'mLS1John in forum General HelpReplies: 19Last Post: 05-16-2007, 12:43 PM -
Ebay garage sale!! Fuel Pump, Line lock, Brake lines 9"
By Phantompooper in forum Parts For Sale / TradeReplies: 4Last Post: 05-04-2007, 06:28 AM
