Thread: oil sender
    Member Camaroride32's Avatar
    Marathon, Fl
    Black/Silver Stripes
    2000 Trans am Ws6
    oil sender
    Just curious... can you change the oil sender w/o taking the manifold off. Of course i decided to do the fast setup.. drove it for a day with everything working fine.. then the next morning driving.. the check gauge light comes on and i see i have no oil pressure... god damn sensor!!!!! Just curious if you can do it w/o taking the manifold off, what holds it, and just outta curiosity, what would a shop charge to change it because if its cheap maybe ill just save me the trouble......
    Senior Member
    Jacksonville, FL
    Never tried it with the manifold on - you can pick up a special socket for it when you get the sensor that should help, but it's a pain to reach. It just screws in.
    retired racer not 4 long chevy1966's Avatar
    mississippi
    red white
    1999 z28 vert 1998 z28 ht
    I did the same thing Friday. Broke mine off installing new intake, got everything hooked up, cranked her up, NO OIL PRESSURE. Pulled the intake back off today, replaced and reinstalled, but was xtra careful. I just do not see how u can get to it with the intake on though. Heck I had mine back on in less than a hour. BTW, it takes a deepwell 1 1/16" or 27mm socket, preferibly 1/2" drive. HTH.
    Senior Member 01ws6er's Avatar
    The 717
    2001 Trash Can
    I'm not 100% sure on this but you might be able to get to it if you pull the driver side valve cover/ coil packs out of the way, but then you still have a rats nest from the air pump valve thing. When I had my valve covers off I could see it, but it's such a small space that it's just worth pulling the manifold again.
    It happens to EVERYONE man lol! It sucks, but hey, at least you'll be nice and fast at it haha.
    NC
    1998Z28
    Look I weigh close to 300#s. And If I can crawl up in there with a thin walled sensor socket ( a regular socket will not work!!) and change the bitch out without removing anything. Then all you young skinny dudes ain't got no excuses. A NAPA Sensor Socket and a mirror on a stick and 15 minutes is all that is required. You don't have to remove anything!!! Just make sure the motors cold before you crawl in there!!!
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    Marathon, Fl
    2000 Trans am Ws6
    alright.. thanks for all the info.. ya i was pretty sure you could change it w/o removing the manifold... just making sure...
  1. Question: 98 Z28 Oil pressure sender?
    By Bigjames25 in forum General Help
    Last Post: 09-20-2013, 05:25 AM
  2. Oil Pressure Sender
    By pajeff02 in forum Tools
    Last Post: 10-17-2010, 04:31 PM
  3. Is my oil pressure sender intacked
    By kb274868 in forum External Engine
    Last Post: 01-15-2010, 08:27 PM
  4. cooling temp sender
    By 02sscamaro in forum General Help
    Last Post: 05-07-2007, 02:12 PM
  5. Which adapter do I need/Where to put sender?
    By MagicMan in forum General Help
    Last Post: 10-07-2006, 07:38 PM
