Results 1 to 15 of 15
Thread: best 60' on 245/50-16
03-18-2008, 05:44 PM #1
what is the best 60' time someone has been on a 245 series tire. street,dot drag , or slick. doesn't matter.
seeing what i should shoot for and what is possible with the 245 nittos i run. A 1.59 would be awesome but i'm not sure if mine will get much better than a 1.65.
so far a 1.74 is my best, but that was only my second run with my setup i had, and since then i removed 110lbs off the front tires and got an aluminum driveshaft. I have heads and am buying a cam so that will give me more power off the line and we'll see if i have traction issues. I love pulling up to oldcars with 11.5 slick and hole shotting them
03-18-2008, 06:39 PM #2
I went 1.59 on m/t 255/50 16's et street radial.
1998 WS6 Trans Am
03-18-2008, 06:52 PM #32000 auto camaro
13.54 @ 104 2.049 60' stock 2.73
12.94 @ 109 2.002 60' full exhaust, lid, tune, nitto 555r 2.73
11.899 @ 114.44 1.686 60' full exhaust, lid, tune, nitto 245/50-16 555r 3.73 moser 12-bolt 2800 fuddle, ls6 intake manifold, slp under drive pully,fiberglass hood, bmr k-member
03-18-2008, 06:55 PM #4
do you have any pics or vids from you 1.59 launch? do you pull the tires with those 255.
a guy i work with says i'll never pull a tire with a 245........well see
03-18-2008, 07:01 PM #5
No I don't have any with those tires but I don't think I pulled the tires. I'll vid this weekend I'm running on 26 8.5 m/t slicks maybe then but I'm on stock susp. so I doubt it you need a low gear and goo susp.
03-18-2008, 07:07 PM #6
do you have your front bumper support,sway bar, or anything else to remove weight from the nose?
03-27-2008, 10:36 AM #7
03-27-2008, 10:47 AM #8
- Apr 2006
- Indianapolis, IN
All Black- 83, 87, 02 All WS6 T/As
My best run to date... with a 1.61 60ft... looks like the front came close.. and thats full street weight.
http://videos.streetfire.net/video/N...215_108127.htm-Geno
1983 Black WS6 "WindCharger"
1987 Black WS6 "WS87"
Sold the other four f-bodies
03-27-2008, 01:35 PM #9
Very close if you get some skinnys they may come off.
04-03-2008, 07:18 PM #10
new 60' time of 1.686 with the 245 nittos
04-13-2008, 04:07 PM #11
- Jul 2007
- corinth, Mississippi
white- 2001 b4c camaro
I've been 1.74 on Nitto's drag radials.. I went a 7.73 at 89mph
04-14-2008, 08:32 PM #12
Any on e here think i can hit 1.59 on these baby nittos?
04-14-2008, 08:47 PM #13
- Jun 2006
- houston, tx
red ta orange gto- 97 trans am 06 gto
ask sarge. he pulls the wheels off with a 245. wider is not always better
04-15-2008, 08:26 PM #14
- Jul 2007
What air pressure have most of you guys had sucess at.. on the nitto's 245/60/16 drag radials.. or what should I run in mine I guess is what I'm asking... car is an automatic
04-17-2008, 06:56 PM #15
i had 37 psi 2 weeks ago and ran a 1.71 60' on a 60 degree night. I lowered them to 25 and managed a 1.686
