Results 1 to 2 of 2
    Junior Member BlueTA99's Avatar
    Houston, TX
    Navy Blue
    1999 Trans Am
    Question Oil Pressure Problem...
    hey was up! i have a 1999 Trans Am (Non-WS6) 6 speed manual transmission
    everything is stock nothing is done to it but a regular K&N filter, other than that it is bone stock from the factory...
    lately i been having an oil pressure problem...
    at cold start the oil pressure is well over 40 ( im guessing 50 since its between 40 and 60)... n thats always at a cold start
    now when im driving n warmed up, the oil pressure is at 40 (while im crusing)... but then after a little while, when im at a complete stop the oil pressure starts to drop little by little n the needle starts reading the oil pressure around 35... n then sometimes the needle starts bouncing from 35 to 39 back and forth (bouncing rapidly is that normal??)... when i start from 1st gear (regular driving) the oil pressure goes back up to 39-40... now lets say im doing 2500rpm on 3rd gear then i press the gas pedal half way i accelerate n it goes up to 4000rpm (still in 3rd gear), the oil pressure barely goes a little above 40...im guessing around 41-42 (i know its no more than 45)... and on top of that while reaching 4000rpm it starts to make a rattle noise (maybe my lifters or something from the valvetrain but i could/can be wrong)... the noise is pretty loud, i believe bcus of low oil pressure is wats making that noise (that its not getting enough lubrication) i could hear it from inside with windows up and down and is very annoying and personally it hurts me hearing that noise cus i feel that im screwing up my engine n now im afraid of going above 3000rpm...
    but despite the noise n the oil pressure drop, the car is doing perfectly fine, i use my Trans Am as a daily driver to go to school and work n do erins, as long as i drive regular the car is good
    my TA has around 60,000 miles, i dont know if the oil pump is acting up cus i hear that 1998-2000 models have bad oil pump, and i also hear that 1998-2000 that has over 50,000mile n having low oil pressure at warm temp. needs to change oil from 5w-30 (currently running) to 10w30 or is it my oil pressure switch???
    so please i need help, opinions, advices, facts, suggestions or anything else please let me know...
    i really appreciate you for taking your time reading this.
    Member 2-bowties&abird's Avatar
    Jan 2008
    lancaster,va.
    cam/lt headers
    blue 2000 ws6 m6
    i wouldn't worry unless it gets to much under 30. alot of people say it's still ok lower than that.
  1. Help oil pressure problem
    By tom70 in forum Internal Engine
    Last Post: 03-23-2012, 04:46 AM
  2. oil pressure problem
    Last Post: 07-23-2011, 08:40 AM
  3. Help: Oil Pressure problem
    By cruiserdanb in forum Internal Engine
    Last Post: 03-25-2009, 06:55 PM
  4. Oil Pressure Problem
    By Tonik in forum General Help
    Last Post: 10-16-2007, 07:27 PM
  5. 383 low oil pressure problem
    By fastrthanurs in forum Internal Engine
    Last Post: 06-08-2007, 04:40 AM
