Results 1 to 17 of 17
    Member nuttyprofessor's Avatar
    New Jersey
    street suspension???
    I know alot of people have been asking which suspension is best for the 4th gens......and usually I read an answer which says "go Koni".
    At nearly $850 a set are they really that much better then say the revalved bilsteins from strano?
    Toledo, Ohio
    1998 Camaro
    I have an Eibach Pro Kit with KYB Monotubes, along with Addco front and rear bars, Lakewood LCA, and Lakewood Panhard rod. I am very happy with the overall performance. THe ride is compliant (I switched from Eibach Sport Line and Bilsteins), and the car more stable at high speed. It feels planted and controlled. My 60' time improved 4/10th with this set up as well. The shocks set me back $280 and springs were $260. I have only put 3000 miles on this setup, but so far the shocks aren't leaking and I am still very pleased.
    1998 Camaro SS, Lots of Mods, Bad Driver. 335 RWHP
    1980 Malibu 2 Door Factory 4 Speed, 355, Dart Heads, Comp 280H, Edelbrock RPM + Carb, 8.5" 10 Bolt.
    1995 Jeep Cherokee 2" Lift 30" BFG's, Custom Intake, Catback
    2006 Chrysler 300 3.5L Dual Catback, 20" ARE, 187 RWHP
    2006 Glastron MX175
    kansas
    i would ask strano what he thinks is better, that guy knows alot and im sure he will give you a stright up answer and not worry how much he will make off of ya
    Member sfletch2000's Avatar
    Feb 2007
    Bakersfield, CA
    86 Buick Grand National
    02 WS6-M6 407 RWHP
    he hasn't even been selling the bilsteins anymore, at least thats what i've read
    Brookville, PA
    2001 Z28
    Koni's rock. Always have. If we could get Bilstein's to Revalve, I'd still do it, but we can't get them right now (or for the last year). But they have NEVER been, or were ever meant to be equal to or replacements for Koni's. All these years I've owned my Camaro (since 9/2000) it's been on Koni's.
    Yeah, they aren't cheap. What worth having is? And FWIW, they actually start @ $770 a set they way I do them, but they can run up to $880 and higher with options. And think about this. What do tires cost? And they don't last nearly as long or have the effect on every aspect of driveability like the shocks do.
    Sam Strano
    SCCA National Champion (x6)
    SCCA ProSolo Class Champion (x5)
    2009 SCCA ProSolo Overall Champion
    Owner--Strano Performance Parts
    814-849-3450
    New Jersey
    Is there a truly noticeable difference between the Koni's and the Tokico's?? I don't drive teh car as much as I'd like to and central NJ roads aren't exactly known for being good driving roads---potholes and traffic lights (OH JOY).
    Just trying to see if they are truly worth the investment as I have a couple projects in the works now.
    Brookville, PA
    2001 Z28
    There is a difference, yes. If your stock stuff is trashed, the Tokico's will make a big difference for not a ton of cash. But the control, ability to tune the ride/handling, and build quality/durability/warranty support are not similar at all.
    ls1ftw tigersport14's Avatar
    Tulsa
    98 trans am
    you have to tune your ride after you get new shocks?
    Brookville, PA
    2001 Z28
    If you have adjustable shocks you can, and should set them to what you like best. Non-adjustables you bolt on and have to settle for whatever the based valving is.
    Member jd2002ss's Avatar
    Clinton Twp. , Mich.
    2002 ss Convertible
    Sam,
    I'm going to install your springs and Koni SA's, will I need a wheel alignment afterwards? I only have 22k miles on the car now and alignment has not a problem.
    Thanks, JD
    Bay Area, CA
    Im not Sam - But yes you will!
    Brookville, PA
    2001 Z28
    Any time you change the ride height the alignment will need done. You are changing the control arms angles, and lowering the steering rack, changing the angle (and basically the length) of your tie-rods.
    Tulsa
    98 trans am
    Quote Originally Posted by Sam Strano View Post
    how much is an alignment?
    Brookville, PA
    2001 Z28
    Depends where you like. $50-60 around here for a 2 wheel (all an f-body nees), can run $100 or more.
    Tulsa
    98 trans am
    oh ok, thanks
    Senior Member Carlos01SS's Avatar
    Aug 2003
    Cypress, CA.
    I've spent $100.00 last front wheel alignment.
    Member Tnhillbilly's Avatar
    Tennessee
    2000 Camaro SS #2364
    I got my Umi bar, Konis and Strano springs from Sam, I couldnt be happier!! My alignment was$40.00, set to Sam's recommended specs.
  1. Front Suspension Work / Completed Rear Suspension
    By bhunter0830 in forum Suspension and Handling
    Last Post: 07-02-2013, 01:23 PM
  2. Front Suspension Work / Completed Rear Suspension
    Last Post: 04-13-2013, 05:44 AM
  3. Question: Street suspension
    By BANDITO in forum Suspension and Handling
    Last Post: 10-12-2009, 09:30 PM
  4. 1967 Pontiac Firebird Suspension Upgrade - Suspension Ascension
    Last Post: 01-17-2008, 04:50 PM
