03-17-2008, 08:01 AM #1Member
- tx
pewter- 99 trans am ws6
whining noise after car is shut off
i have a whining noise coming from the hood after I shut the car off. It slowly comes to a stop after something stops spinning. What can this thing be.
03-17-2008, 09:05 AM #2
can be, the fans or the air pump. Best things I think of.
03-17-2008, 05:30 PM #3Member
- Jan 2006
- houston
Navy Blue- ls1 trans am
Might be your head light motor gear stripped.... it will make a plastic grinding noise when you turn the car off. see if the noise is coming from either head light.l
03-17-2008, 08:03 PM #4Member
- tx
i had the grinding noise from the headlights and I know that one is not it. Im thinking its my air pump.
03-18-2008, 10:57 AM #5Senior Member
- Jul 2005
- Jacksonville, FL
Pull the AIR PUMP fuse under the hood while it's making the noise...normally not running when the car is hot though.
03-18-2008, 04:00 PM #6Member
- tx
so the air pump does not run after the car has been driven. the only time that I hear is when i get out of the car after it has been driven. If the air pump is only on while the car is warming up them that probably is not it.
03-18-2008, 04:15 PM #7Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
if you had your AC on, its your condenser fan, no worries there.
whining noise??
By via sin dios in forum Firebird / WS6Replies: 17Last Post: 10-29-2015, 02:34 AM -
whining noise when A/C is turned on
By y2kformula in forum Firebird / WS6Replies: 9Last Post: 10-29-2008, 10:23 PM -
Help: whining noise when A/C is turned on
By y2kformula in forum General HelpReplies: 3Last Post: 10-26-2008, 03:33 PM -
whining noise 94 z28
By t-rock in forum General HelpReplies: 1Last Post: 01-14-2008, 07:40 PM -
help with whining noise please!
By 1998zman in forum General HelpReplies: 3Last Post: 03-26-2006, 01:18 AM
