Thread: ford 9in
    Feb 2008
    york pa
    96 ws6
    ford 9in
    Did anyone swap in a ford 9in and need to get a longer driveshaft. My shaft is sticking out about 3 in. and makes a slapping sound the second the car starts moving. The rear is from quick performance
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    I used my stocker and was fine. I then bought a Strange 3" chromoly one and it was a little less than 1/2" longer than stock and still ok.
    I also bought my 9" from quick performance.
    Do you have adjustable suspension parts? if so you might need to do some adjusting?
    Did you get a Detroit locker? If so they make a lot of noise and that's what you might be hearing?
    I know mine makes some racket.
    Feb 2008
    york pa
    96 ws6
    i dont have any suspension parts except a aftermarket torq. arm and its not adjustable. I had them put a mini spool in the center section with 3.50 gears. Did ur rear get quiter as u broke it in?
    Lathrop, Missouri
    NBM / Silver
    Quote Originally Posted by fastlt196 View Post
    mini- Spool should be nice and quiet. What kind of drive shaft do you have? What conversion u-joint did you use? Maybe you can post pics of your engagement into your transmission. other than that? I don't know. I have not herd of the driveshaft ever being too short.
    Billings,MT
    Sunset Orange Metalic
    2002 Firehawk
    I was told the driveshaft for the 9" F-body fit is 1 inch longer.
    Feb 2008
    york pa
    96 ws6
    a just had another guy tell me the driveshaft is a inch shorter than it should be so it looks like i will be measuring for another driveshaft. Thanks
    Lathrop, Missouri
    NBM / Silver
    let me know, I know where you can get a Strange 3" chromoly one with 1350 yokes , strange sealed u-joints rated to 1000 hp for $295 shipped
    Billings,MT
    2002 Firehawk
    Sorry I ment shorter - My bad !
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    hum, mine fit PERFECT!!!!!!!
    Feb 2008
    york pa
    96 ws6
    i put a longer yoke on the front and it works perfect. How much noise should u hear from the rear because it definetly is not silent? love the 3:50 gears
    Lathrop, Missouri
    NBM / Silver
    With any after market High performance rear end with hardened gears, you will get some noise out of them. (the price you pay if you want to play) But if it is overly overpowering something could be wrong. When I said nice and quiet, I meant not as bad as mine LOL.
    I have a Detroit Locker and it bangs, clunks, makes loud metalic noises, But I knew that when I bought it and it makes a good conversation piece.
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    Mine was a bolt in nothing needed driveshaft wise.
  1. 2009 Ford Flex - Hot Rod Ford Flex
    Last Post: 08-10-2009, 10:00 PM
  2. 1932 Ford Pickup RAT ROD Three Dueces 312 Ford
    By fuzzyhall in forum Vehicles For Sale / Trade
    Last Post: 10-25-2008, 08:36 AM
  3. Ford 4.6 Engine - Junkyard Jewel Ford 4.6l 2v -
    Last Post: 04-11-2008, 07:05 PM
  4. LS1 in 51 Ford
    By 55newbie in forum Computer & Tuning
    Last Post: 01-08-2008, 11:32 AM
  5. C6 ZO6 vs Ford GT
    By SeVeReDiStOrTiOn in forum Almost Anything Goes
    Last Post: 05-13-2006, 08:12 AM
