03-16-2008, 03:04 PM #1Member
- Feb 2007
- Bakersfield, CA
86 Buick Grand National- 02 WS6-M6 407 RWHP
Installing Struts, Need help ASAP
I attempted to intall my koni's and strano whites today, as expected the rears shocks/springs went smoothly. I got the fronts out without much trouble, but i had trouble geting the rubber strut boot and bolt off off the top of the shock, I'm going to take the new struts and springs to a shop and have everything disassemble and the news assembled.
Here's my question which is probably a stupid one. But once everthing is together, will i be able to turn the bottom of the shock to get the holes lined up with the lower a arm bolt holes. What i'm getting at is once the strut is assembled and i'm putting everything together the bolt holes and studs will go up into the top of the car and obviously the angle of the bolt holes on the bottom of the shock aren't going to be the same as the original strut so will the shock itself turn to line up the holes on the lower a arm or will the spring tenion not allow it to. If so how do i make it too
03-16-2008, 03:22 PM #2Cookie Monster
- Apr 2007
- Watertown, New York
Navy Blue Metallic- 2002 Z28
Yes you will, I just did my springs today, well 3/4 of them anyways lol. But yes, you can turn the strut enough so eveything lines up ok.
03-16-2008, 05:11 PM #3Member
- Feb 2007
- Bakersfield, CA
well lets say if when the guys put the stuts together the bottom shock mounts are a full ninety degrees off, can you still turn it. Do i need to tell them how everything willl line up so its close?
03-16-2008, 05:58 PM #4Cookie Monster
- Apr 2007
I think you might be able to turn it that far, but im sure the mechanic will line up the strut mount to the bottom of the shock like the old one.
03-17-2008, 08:34 AM #5Member
- Oct 2005
- CT
White Liquid Silver- 2000 Camaro SS/ 02 YZF-R1
Can you post pics of your car after the install please, this is the same set up I'd like to get and want to see the stance. Thanks!
03-17-2008, 01:52 PM #6Member
- Feb 2007
- Bakersfield, CA
Just go here and click on the pic to enlarge, it shows a camaro with the springs installed.
http://www.stranoparts.com/partdetai...ID=0&ModelID=8
I suggest just removing the struts and taking them to a shop to have everything switched over from your old strut/spring combo to the new. Fighting a cheap spring compressor is a pain in the ass.Pacesetter Headers- ORY
Texas Speed 228R Cam/Moly Pushrods/918 Springs
MTI LID
Slp Under Drive Pulley
Texas Speeds Rumbler Catback
SFC's, Lakewood LCA's
Koni SA 4/3, Strano Springs
Dyno Tune
LS7 Clutch, Nitto DR's
407 RWHP 377 Ft./lbs.
struts '02
By johnfin in forum Firebird / WS6Replies: 1Last Post: 09-08-2012, 02:15 PM -
Ss hood struts
By MNZ28 in forum Camaro / SSReplies: 1Last Post: 09-10-2009, 07:38 PM -
struts
By shadowsnkx in forum General HelpReplies: 2Last Post: 07-29-2008, 05:08 PM -
installing rear lowerings springs and struts
By adham in forum Suspension and HandlingReplies: 21Last Post: 08-04-2007, 06:34 AM -
4th gen struts
By toplessHO in forum Parts Wanted / TradeReplies: 9Last Post: 11-06-2006, 04:58 PM
