Thread: dumbass question...
03-15-2008, 07:43 PM #1Junior Member
- Aug 2007
- saginaw MI
Blue- 2000 Camaro SS Convertibl
dumbass question...
OK, I know I'm gonna get ripped here, but I'm a novice to the muscle car scene, and this terminology kills me...what the hell is a "rear"? I hear about cars with a "4.40 rear changes to a 3.20 rear" and I don't know what the hell they are talking about! Could someone give me the basic definition of this term? I'd appreciate it.
03-15-2008, 07:49 PM #2Fuzzbuster Jr.
- May 2007
- Cave Run Lake area, Kentucky
Pewter- 2002 T/A WS6
The gears in your rear end (the car). Their ratio.
03-15-2008, 07:58 PM #3
is correct depends on if you have 5 or 6 speed what you want a ratio like 4.10 has a lot more acceleration in the early gears but you lose top end and something like a 3.73 doesn't pull off the line soo much but will have better top end i stick with that cuz i have a 6 speed and it accelerates well but i still have plenty of top end and gas mileage doesn't suffer 80mph i'm still under 2000rpm's in 6th gear
03-16-2008, 07:34 AM #4Internet Tough Guy
- Nov 2007
- Oregon
Sinister, SixGun- 2001 SS, 2002 L36 M5
stick with 3:42's (if you have them) you'll be more than happy.
03-16-2008, 07:44 AM #5
03-16-2008, 07:47 AM #6
There is no such thing as a stupid question, everyone has to learn somehow, Knowledge is only useful when it is shared!!! The ring and pinion gear in the rear axle is what they are referring to. The numbers they are talking about is a ratio, the higher the ratio number is the more low end acceleration the car will have, also in turn though, the car will not achieve the top end speed because the motor is hitting its max revs earlier. The lower the number the slower acceleration the car will have, but it may hit a higher top speed if the horsepower is there to do it, and it will be better on fuel economy due to turning less RPMs.
This is what will confuse you, when they are talking about putting a lower or steeper gear in the car they do not mean the numbers themselves are lower, so if someone had a 2:73 to 1 ratio and they said they lowered the ratio on the car the numbers would have actually went up, say to like a 3:42 to 1.
hope this helps you understand.
03-16-2008, 07:53 AM #7Internet Tough Guy
- Nov 2007
- Oregon
you very well may be. but for someone whos getting into all of this, a stock set would probably be more beneficial and simplistic.HUGH?
I got 4.30's and I am alot more happy than haveing the 3.42's.
having
Dumbass
By TARZAN in forum Almost Anything GoesReplies: 3Last Post: 05-30-2009, 06:12 PM -
I am a dumbass,,,,
By Smkn_TA in forum General HelpReplies: 11Last Post: 12-29-2007, 07:59 AM -
Dumbass of the week
By 86 IROC-Z in forum Almost Anything GoesReplies: 11Last Post: 09-24-2007, 04:00 PM -
before i look like a total dumbass....
By NE98LS1 in forum Almost Anything GoesReplies: 21Last Post: 06-04-2007, 07:46 PM -
i'm a dumbass...
By NE98LS1 in forum General HelpReplies: 10Last Post: 04-13-2006, 09:27 AM
