Results 1 to 11 of 11
    Every day is a gift-enjoy preston1980's Avatar
    Missouri
    Torch Red
    1999 Corvette Hardtop
    Unhappy major clutch problems!!
    ssdd
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    You may want to try a new master as well...replacing the slave is only half of the problem in the 98-00 cars. I did a new master & slave when I replaced my clutch and haven't had any stupid problems with it yet!
    Missouri
    Torch Red
    thanks
    I thought it was only the slaves that were shit in the 98-00 6 speeds.
    So I only replaced the slave cylinder, but I'll do the master now as well.
    Thanks.
    Hey what is this drill mod good for? I keep seeing it on threads, but I dont know if I need it if I get updated slaves and master cylinders on my 99 TA.
    What is the drill mod and will the new master and slave need it done before installation?
    Missouri
    Torch Red
    do i need a new clutch now?
    Also, I was wondering if I can still use my slp zo6 clutch, now that I spun the shit out of it in the bell housing? It only has 600 miles on it? Or can I reuse it and just resurface the slp steel flywheel?
    Alcohol Injected PaganEgyptian's Avatar
    Knoxville,Tn
    1999 Pontiac Firebird
    Thats line restriction, you need to drill out the restriction in the slave line. Use a 3/8" drill bit. GM knows about it, its a major clutch killer. They owe you a new Clutch due to the restrictor they keep putting in it. When will GM learn.. prolly never.
    sonnyred
    Guest
    Are you sure it's3/8ths installuniversity.com states 1/8 drill bit .NOW I'M REALY CONFUSED. Are you sure?
    Charlotte, NC
    99 Firebird Formula
    It is 1/8th. 3/8ths would be a pretty big hole....
    Missouri
    Torch Red
    where do you drill?
    Im getting a master and slave cylinder from gm. They are connected and pre bled. So it comes with a new line. Do i still need to drill it before install? Also which end is it, and where do you drill?
    I still dont know if i can reuse my clutch kit? Should i just resurface the flywheel or is the clutch toast?
    sonnyred
    Guest
    Quote Originally Posted by preston1980
    If the kit is for 2001or2002 proberly not,but if you need instructions go to --installuniversity.com it shows the procedure.
    Knoxville,Tn
    1/8th.... my bad.... The restrictor is about 2" inches into the line, best way to find out is to use a drill bit and insert it without turning it. It should hit an obstruction. thats you line restrictor.-Tim
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Your clutch shouldn't be toast, if that's all they could take none of us could drive them for more than a week. . .
  1. T-56 major problems need help???
    By miller456 in forum Manual Transmission
    Last Post: 08-14-2007, 12:04 PM
  2. major tranny problems, need help
    By import slayer in forum Automatic Transmission
    Last Post: 02-21-2007, 02:52 PM
  3. Help Major Problems
    By LT1Redneck in forum LT1
    Last Post: 02-14-2007, 06:26 PM
  4. Major Problems
    By dude2000_22222 in forum General Help
    Last Post: 11-06-2006, 03:53 PM
  5. major tuning problems
    By blky2k2z in forum Computer & Tuning
    Last Post: 10-09-2005, 07:05 PM
