    Feb 2006
    Oklahoma
    its blue.....
    1999 Trans-Formula
    Subframe Connector ?
    I got a good deal on some SLP Bolt On Subframes that are brand new and never been used, I have heard a few people tell me I should weld them in even though they are supposed to bolt right up is there really that much of a difference or should I just bolt them up and leave them be?
    Drag racing is a disease! RacerBob's Avatar
    Feb 2008
    Youngstown, Ohio
    Maroon
    2000 Z28
    For most applications bolt in will be OK; however, a weld is a much stronger bond than a threaded fastener.
    Junior Member shanepatrick1230's Avatar
    Lockport, NY
    99 Trans am Convertible
    i think the weld in ones come with extra places for welding along the subframe, so if u have the bolt in ones.. i am not sure. bolting should be ok, but welds dont come loose...unless they break..
    # 1846 mahoney1's Avatar
    Malden Ma.
    CETA Yellow
    2002 WS6 CETA
    Do you need a drive on lift to install bolt on SFC's?
    Feb 2008
    Youngstown, Ohio
    Maroon
    2000 Z28
    Quote Originally Posted by mahoney1 View Post
    No. Check out the instructions: http://www.exoticperformanceplus.com...php?service=13
    This is for weld in SFCs, but the bolt in's don't want the chassis to be loaded either.
    Cedar Rpaids,IA
    1998 Camaro SS
    Welding is always the strongest, but once they are in it is hard to unweld. Where the bolt-ins you can unbolt them to work under the car etc. Performance difference between the two: on the street my 2cents you will not be able to tell the difference. A race only app. I still don’t think you well see a difference in performance.
    I personally have the bolt-ins and have had no problems after 3 years of use.
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
  1. Question: Subframe Connector Info
    By jcws6 in forum Suspension and Handling
    Last Post: 10-17-2011, 07:55 AM
  2. Subframe connector question
    By 02blckws6 in forum Suspension and Handling
    Last Post: 10-20-2010, 02:57 PM
  3. subframe connector help
    By pewterWS6-2000 in forum Suspension and Handling
    Last Post: 08-16-2008, 01:58 AM
  4. Subframe Connector Question?
    By camarostripes96 in forum LT1
    Last Post: 05-15-2008, 06:10 AM
  5. subframe connector
    By uwilluz in forum Suspension and Handling
    Last Post: 04-20-2006, 08:14 AM
