    Senior Member 00z28bubba's Avatar
    las vegas, nv
    2000 Z28
    getting power to the ground through suspension
    im currently looking for any and all SUSP. MODS that wil get more power to the ground currently i have just full exhaust and near full intake with the exception of and intake manifold and the numbers i am currently running are 306whp and 323wtq. if you have any info that you think will help let me know i currently have sub frame connecters and tower bar on the way.
    p.s.
    forgot to mention for street use mostly track will be a while i need another car before then
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    straight line only ?
    grip in cornering important ?
    best thing to get better grip, is shocks, proper diff (like a T2R) and a decoupled-TA (UETA)
    Eugenio_SS
    las vegas, nv
    2000 Z28
    i automatically assumed grip for cornering would come with majority of suspension upgrades but the car is a daily driver that is why i am going with suspension as apposed to power adders. any type of susp mod that will get grip would be great cornerin is not a big issue because it wont have the power to make it an issue as it will be a daily driver for another year at the least. i mean that in a way that it wont be seein any road courses and/or street racing. and the track wont be hit for another 4 months. im still in the process of clean up work so i can get through emissions tests. if you guys can try to explain the pieces in a simple manner so when im looking for parts i won't be completely lost
    Jun 2002
    Montreal, CANADA
    triple-black
    good shocks will do all of your goals pretty well to the level that might satisfy you.
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    if u looking at making the car grip better u might want to get lca's and relocaters, i went from a 2k drop on the street to now im droping at 3300 rpm on the street note that i also have put a light weight fly wheel in as well but i dynoed 341 whp and 352lbs of tq and its a dead hook at 3300 rpm
  1. G8 Power to the Ground with Performance Differential
    Last Post: 11-10-2013, 04:18 PM
  2. G8 Power to the Ground with Performance Differential at SEMA
    Last Post: 11-08-2013, 02:24 PM
  3. Ground Kontrol........from the ground up.
    By dneemorelos in forum Texas Members
    Last Post: 02-23-2009, 05:46 PM
  4. 1967 Pontiac Firebird Suspension Upgrade - Suspension Ascension
    Last Post: 01-17-2008, 04:50 PM
  5. Suspension Middle Ground
    By ls1camino in forum Suspension and Handling
    Last Post: 11-17-2007, 07:21 PM
