Results 1 to 13 of 13
Thread: question :(
03-11-2008, 08:02 AM #1Junior Member
- Jan 2008
- KUWAIT
RED- 1999
question :(
Hello all
There is a question in my mind .. There Block and heads for the Sierra 2500 HD (heavy duty) , I can replace it in my camaro engine ?
Thank you
03-12-2008, 06:30 PM #2
Yes you can but make sure and use the camaro accessories.
03-13-2008, 09:59 AM #3Junior Member
- Jan 2008
- KUWAIT
RED- 1999
somebody told me that impossible !!
cause it very big .
03-13-2008, 03:00 PM #4
It's a bigger bore but if you use the block and heads and make sure you have the correct intake the physical outer dimensions should be the same. You will still have to use the F-body accessories. I see 6.0 going in camaros all the time.
03-13-2008, 03:05 PM #5Junior Member
- Jan 2008
- KUWAIT
RED- 1999
yeah but sierra 8.1 L it give me more hp
so i want steps cause i want to do it soon
but i dont know what can i do
03-13-2008, 03:11 PM #6
So are you wanting to put something with more HP in the truck or Camaro and what year model is the Camaro?
03-14-2008, 11:02 AM #7Junior Member
- Jan 2008
- KUWAIT
RED- 1999
i want to put sierra 2500 hd engine in my camaro
cause it can give me more hp and its Cheaper than ls1 engine
Therefore, i want to make sure if i can put it in my camaro body or not ?
(my camaro is z28 ls1 99' )
03-14-2008, 06:40 PM #8
Just wanted to clarify, yes you can with the LS1 or LS6 intake and accessories. Physical dimensions are the same.
03-15-2008, 12:59 AM #9Junior Member
- Jan 2008
- KUWAIT
RED- 1999
When replace it and finished off what should I do to the best of their level ?
I mean ( kinds of supercharger i can use, intake,headers and injectors ?
03-15-2008, 10:11 AM #10
STS Turbo, Magnacharger, Procharger or whatever you like within reasonable boost levels to the stock motor.
03-19-2008, 05:50 PM #11
03-20-2008, 09:57 AM #12
No, an 8.1 will not fit without modifications I was refering to the 6.0. I thought I read 6.0 in one of the threads not 8.1. The 8.1 is externally bigger so my mistake.
03-20-2008, 10:52 AM #13
speedometer question + top speed question
By Krazy351w in forum General HelpReplies: 7Last Post: 06-21-2007, 05:51 PM -
HPIII question (not the same old question)
By slims00ls1z28 in forum Computer & TuningReplies: 5Last Post: 06-01-2007, 04:55 PM -
97 Bird Headlight question also engine noise question
By Zapper2003 in forum General HelpReplies: 2Last Post: 12-13-2006, 03:03 AM -
Speedometer question, RPO question
By acrylicophobia in forum Firebird / WS6Replies: 12Last Post: 11-02-2006, 07:08 AM -
Sex Question spinoff- PORN QUESTION
By egaian in forum Almost Anything GoesReplies: 77Last Post: 07-26-2006, 03:07 PM
