Thread: Turbo question
    Junior Member maxgee's Avatar
    Feb 2006
    S Florida
    35th SS LE
    Turbo question
    I'm picking up my turbo kit this weekend. It's a custom set up. It comes with :
    Intercooler
    39lb injectors
    Turbo
    piping
    clamps
    BOV
    Wastegate
    Fuel pressure regulator
    6.0L ported heads
    I already have 255 Walbro pump installed.
    The heads are ported but stock valve train.
    I'm getting ARP head bolts
    I was wondering if I should get new stronger springs and pushrods?
    I will be running 8psi spring on the Wastegate.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    those injectors won't go much past that 8psi, and may run out before depending on your level of modification
    Junior Member Chad Nielson's Avatar
    Springville, UT
    02' Camaro SS
    Frost is probably right, (I would use 42#) also the stock valve springs will usually start to float around 8psi. So if you want more boost i would get different springs.
    A TYPICAL DAY AT WORK!!!!
    Feb 2006
    S Florida
    35th SS LE
    Just checked into upgrading and found out the injectors I have are good.
    The injectors are from 03 Cobra 39ilbers rated at 43.5 psi
    but with 58psi on the LS1s puts me at 45lbs on the injectores.
    Springville, UT
    02' Camaro SS
    Hey Frost what do think about the MSD Boost a Pump?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by Chad Nielson View Post
    I have one on my primary pump, but not my secondary. Since it's always been part of the system, to be honest, I'm not sure exactly what it's worth, but I've seen it stretch some vette's out that were around 540-and slightly up rwhp by 25-45 rwhp. I'm not sure what MSD claims, but that was my experience on those two. Clemsondave's (04 Z06, stock vette pump) setup had one from the get-go and makes 550-575rwhp depending on the dyno and the day with meth and 42s.
    KACHME 001CamaroSS's Avatar
    Glendale AZ
    Silvaa
    2007 Corvette
    Where'd you get the custom setup from? Is it remote mount. I've been trying to decide how to turbo my car and I don't think I want remote mount... I've only seen APS, gale banks, and HPPerformance with front mount kits, so im curious
    Feb 2006
    S Florida
    35th SS LE
    Quote Originally Posted by 001CamaroSS View Post
    Couple of guys here in S. Florida made the kit.
    Here's a couple of pix and the email if your interested in more info to one of the builders of the kit
    xfenix999x@aol.com
    They are working on another kit that allows you to keep the battery in stock location. I had to run mine to the rear. We just installed the kit this past weekend.
    I still have to do a couple of things; sheild the turbo, wrap the traction control and weld up the center exhaust pipe. Waiting on my wideband to get it to a muffler shop for the welding.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Pics and info on my f-quick page
    http://www.fquick.com/Frost
  1. Turbo Question
    By Conquest LR4 in forum Forced Induction
    Last Post: 06-19-2014, 04:45 PM
  2. Turbo/cam question
    By woodymaro in forum Forced Induction
    Last Post: 07-30-2011, 05:08 AM
  3. another turbo question
    By ttopz28 in forum Forced Induction
    Last Post: 02-24-2010, 03:08 PM
  4. STS TURBO hp question?
    By 00TAWS6 in forum Forced Induction
    Last Post: 08-16-2006, 03:21 PM
