Thread: 6.0 stroker
03-06-2008, 12:53 AM #1Junior Member
- Mar 2008
- kuwait
6.0 stroker
i`m thinking to chang my engin the 5.3 to 6.0 strocker 408 i need to know how i can make sure its good block are there any way to chek it the 6.0 have :
1-eagl crank
2- daimonde peston
03-07-2008, 06:00 AM #2
What are you asking?...need a little more info
03-12-2008, 07:19 AM #3
you will need to get a 6.0 block, i dont think you can make the 5.3 into a 408. get a 6.0 block and take it to a machine shop and ask them to check it out. You can also buy a brand new 6.0 block for about $700.
6.0 block
4" stroke crank
6.125" rods
then you need the correct pistons for your application (boost, nitrous, all motor, etc)
03-15-2008, 10:20 AM #4
to get a 5.3L motor to a 408 size, you would have to replace the cylinder liners. not real cost effective.
03-15-2008, 01:15 PM #5Member
- Billings,MT
Sunset Orange Metalic- 2002 Firehawk
I thinking he is building a 6.0 to a 408 which is the iron block bored out.402 is the 6.0 aluminum not bored with a stroker kit installed.
03-18-2008, 06:08 PM #6
after reading it again, you are correct. he's a little tough to follow.
to find out if it's any good, you would have to pull it apart and inspect all the parts.
03-19-2008, 01:43 AM #7Junior Member
- Mar 2008
- kuwait
6.0
thanks for all the replay
Stroker or not
By hartsmike in forum LT1Replies: 3Last Post: 03-25-2008, 12:35 PM -
Stroker q
By grandkodiak in forum LT1Replies: 12Last Post: 02-28-2008, 08:53 PM -
Stroker kit on LS1?
By Wheeler99WS6 in forum Internal EngineReplies: 25Last Post: 03-24-2007, 07:15 PM
