Thread: Factory ws6 ram air hood HELP
03-04-2008, 10:40 AM #1Junior Member
- Dec 2007
- Toccoa, GA
Silver- 98 Trans Am
i have a ws6 factory ram air hood that i want to repair for my non ram air car. however i'm missing the inserts that go on the front of the hood at the openings can someone help me find some or maybe our damaged hood has them.? some one help it is not the plastic screen but the actual scoop opening
03-04-2008, 10:51 AM #2
I'm lost what exactly are you missing? If you the plastic screen is there, then you ahve the openings. Or are you missing the inserts that fit into the front of the hood?
03-04-2008, 10:55 AM #3Junior Member
- Dec 2007
- Toccoa, GA
Silver- 98 Trans Am
i do not have the plastic screen or insert i just thought that some ppl whould have meant i needed only the screens sorry
i need the insert and screen
03-04-2008, 11:18 AM #4
Ah ok. The front screeens you should be able to find on E-bay or from one of the sponsers here if you want something special. I'm not 100% familuar with the 98 set up so bare with me. But the only thing I can think of that would sit inside the hood would be the baffles that keep large debris and water from reaching the air filter.
Just refreshed my memory, the baffels in side the hood are not criticle. You will be fine with out them.
03-05-2008, 07:15 AM #5Junior Member
- Dec 2007
- Toccoa, GA
Silver- 98 Trans Am
actually i need the part that goes on the outside it is part of the hood itself
03-05-2008, 07:51 AM #6
Ahh, ok, some thing like that you will have to got the dealer for or you may be able to find it from an aftermarket manufacurer. Any way you can get pics up?
03-18-2008, 05:50 PM #7Member
- Dec 2006
- kansas
check your local junk yard
Factory SS hood or not?
By transamgirl89 in forum Camaro / SSReplies: 32Last Post: 09-20-2010, 03:12 PM -
factory WS6 hood
By muscatine73 in forum Firebird / WS6Replies: 6Last Post: 01-01-2009, 04:42 PM -
Needed Factory Hood
By MapleredT/a in forum Firebird / WS6Replies: 2Last Post: 03-31-2006, 12:07 PM -
Needed factory hood not ram air
By MapleredT/a in forum Parts Wanted / TradeReplies: 0Last Post: 03-23-2006, 05:27 AM -
Factory Hood needed
By MapleredT/a in forum Parts Wanted / TradeReplies: 0Last Post: 03-23-2006, 03:36 AM
