Results 1 to 3 of 3
Thread: predator?
03-02-2008, 07:05 PM #1
- Apr 2007
- auburn,ga
red- 2000 nhra formula
predator?
can u use predator to turn off rear o2 or smog pump trouble codes and if so how does that refect emision tests will it still pass i live in GA and cant stand the emissions here used to live in Fl im gettin a p1416 code and cant fix it with out passing i cant drive the car no plate thanks any info i would apreciate
03-03-2008, 10:31 AM #2
- Jul 2005
- Jacksonville, FL
Yes you can turn off air, egr and rear 02's permanently with your Predator depending on the version. P1416 should be an easy fix, replacing the passenger side air check valve usually takes care of it.
03-12-2008, 11:14 AM #3
- Apr 2007
- auburn,ga
well tryed changing bank two check valve still getting code if i use predator to remove codes will i pass emissions here in GA its a obd2 check no sniffer
Question: 02 WS6 and predator
By PGH_WS6 in forum Computer & TuningReplies: 1Last Post: 08-11-2008, 02:40 PM -
predator help please
By rawy2000 in forum Computer & TuningReplies: 1Last Post: 06-10-2008, 02:08 PM -
Predator...
By tyxpx in forum GTOReplies: 9Last Post: 07-02-2007, 08:22 PM -
Predator
By tornado in forum Parts For Sale / TradeReplies: 0Last Post: 06-07-2006, 07:54 AM -
Scc On Predator?
By mikes ss in forum Computer & TuningReplies: 1Last Post: 03-02-2006, 09:30 AM
