Results 1 to 2 of 2
Thread: Ford Rearend Swap questions
03-01-2008, 01:27 AM #1Member
- Mar 2006
- West Virginia
Pewter- Y2K WS6
I know very little just buying my first Trans Am have lusted after them for 10 + years now. I know the rear is weak and the 2 strongest replacements are a Dana 60 and a ford 9" /8:8.
What all needs replaced? will one from a mustang work. how much HP will a stock ford rear end take?
Thanks for the info I appreciate it!
03-01-2008, 06:20 AM #22 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
I have a Moser 9" with a Strange pro nodular Third member with a detroit locker and 35 splined axles. Should hold up to 800 hp. I won't come near that but in any case they are strong.
You are looking at between $2100-2800 depending on options with a 9", and $2500-3300 with a Strange S-60. With the s-60 you will need to shorten your driveshaft or buy a new one. It is pretty much a direct bolt in application in both cases and not too bad of an install.
With the uniqueness of the f-body torque arm mount, It is very difficult to Fabricate a 9" houseing to work properly. It can be done but ends up costing more, looking like shit and turns out to be a big headache. If you want to try and go with a budget build, It would be best to buy a Houseing and Axle package from Moser, then trying to build a thirdmember with parts pieced together through e-bay. I have herd of guys building a pretty decent thirdmember set up for around $800. So if you are really ambitious you could get away with a 9" for around $1900 doing it all yourself and pieceing it together yourself.
Whatever your plans are, Do not build or put gears in the 10 bolt, it's a huge waste of money and if you plan on moding your car and raceing it with sticky tires its not a matter of "If it will break, Its when it will break"
Moser 9-inch Rearend Swap
By midnitejam in forum DrivetrainReplies: 15Last Post: 05-16-2011, 06:17 AM -
rearend swap completed with pics
By Zboner in forum DrivetrainReplies: 16Last Post: 06-17-2009, 09:17 AM -
rearend swap question
By transamerff in forum DrivetrainReplies: 3Last Post: 06-15-2009, 04:01 AM -
Rearend questions
By Al Hazz in forum Automatic TransmissionReplies: 6Last Post: 04-17-2009, 07:43 PM -
Wanted Ford 9" rearend f body
By sscrazy in forum Parts Wanted / TradeReplies: 1Last Post: 02-09-2007, 07:07 AM
