    Junior Member DarkSide00's Avatar
    Feb 2008
    Gwinnett, GA
    02 Z28
    02 z28 gear ratio
    whats my stock gear ratio for an 02 Z28 A4...and what gear ratio is recommended..as in 3.73's or 4.10's
    02 Silver Z28 A4..stock for now
    Feb 2008
    Morrow, Ga
    2002 Camaro Z/28
    You have a 2.73. The gear you want to run will depend on what you intend to do with the car.
    Member kev70ss's Avatar
    Yorba Linda
    2000 Camaro ss
    Check your RPO codes located on the inside of the drivers door, then go here and you can decode it. http://www.camarosource.ca/php/camar...eels&year=2002
    Im pretty sure 3.23 were also available on an auto
    You have 2:73s or 3:23s were an option for Z28s.
    GU2 : AXLE REAR, 2.73 RATIO
    GU4 : AXLE REAR, 3.08 RATIO
    GU5 : AXLE REAR, 3.23 RATIO
    GU6 : AXLE REAR, 3.42 RATIO
    You want 3:73s as an upgrade.
    Painted manta stripe
    Aug 2000
    Indy
    GU5 option code also gives you an aluminum driveshaft.
    Sacto.
    2002 Camaro Z28
    I believe the aluminum driveshafts came only on M6s and 3.23 A4s; at least that's what I've noticed.
    You'll see a big change if you go from 2.73s to 3.73s. Depending on the way you drive the car, your gas mileage may suffer though. I believe my brother went from something like 1600 RPMs at about 70 MPH with 2.73s to 2400 RPMs at 70 PMH with 3.73s. He didn't like them much, even with an SS4000. Strangely, he preferred my 3.23s and SS3800. He eventually swapped axles from a 3.42 car and actually liked it a lot better.
    I think 3.73s for a DD is about as far as you want to go.
  1. gear ratio's
    By Team Villan in forum Drivetrain
    Last Post: 07-28-2008, 10:32 AM
  2. Gear Ratio
    By TransAmFanatic in forum Drivetrain
    Last Post: 03-29-2008, 01:52 PM
  3. Gear ratio vs. take-off
    By slade8200 in forum Drivetrain
    Last Post: 04-14-2007, 05:24 PM
  4. Gear Ratio
    By enjun in forum Drivetrain
    Last Post: 01-15-2007, 12:57 AM
  5. 3.42 gear ratio
    By larryndog in forum Drivetrain
    Last Post: 10-04-2006, 12:45 PM
