Thread: Tire Pressure..
    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    Tire Pressure..
    im going to the track for the first time next month... i know how to launch my ss nicely just wonderin what tire pressure i should have when getting ready to race... i have stock ss rims with toyo proxys
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    run about 25psi on street tires, anything less becomes a drag on the big end and run the front at about 50psi.
    ........BUT if you really want traction get some drag radials(i'm sure you will hear this alot) i run the nitto 555r on my car and as long as you don't do much burnouts they can last awhile. they work for me and my buddy in his 2000 m6 formula cuts 1.84 60' times with the 245/50-16 nitto and stock 3.42 gears.
    2000 auto camaro
    13.54 @ 104 2.049 60' stock 2.73
    12.94 @ 109 2.002 60' full exhaust, lid, tune, nitto 555r 2.73
    11.899 @ 114.44 1.686 60' full exhaust, lid, tune, nitto 245/50-16 555r 3.73 moser 12-bolt 2800 fuddle, ls6 intake manifold, slp under drive pully,fiberglass hood, bmr k-member
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Quote Originally Posted by silverz28camaro View Post
    He might want to keep his rear end lol
    Puyallup
    yup i do wanna keep my rear end
    Washington MO
    sebring silver
    2000 z28
    Quote Originally Posted by 2000SuperSportMaro View Post
    you'll be fine with 17 inch nittos. my buddy has ran his m6 for 2 years now cutting 1.8xx 60' on the factory 10 bolt. even if you cut low 1.9xx your 10 bolt will last very long. its when you dig down to the low 1.7xx with the m6 that you have to start to worry about and high 1.6 with auto cars. so have fun and give that gm car what it wants ...WOT...
    Puyallup
    oh i will
    Member chieftransam's Avatar
    Germany
    Blue
    2001 Pontiac Trans Am M6
    what would be a good tire pressure for launching with mt et street radials?
    Washington MO
    sebring silver
    2000 z28
    Quote Originally Posted by chieftransam View Post
    I run my nittos right t at about 20-25psi and they work good, I would try running 20 in that mt and see what happens, if it hooks near perfect then pump it up to 25 and see what it does. Its all trial and error.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Every car is different!! There is NO universal tire PSI. Your best beat with a street tire is to go to a nice smooth concrete parking lot.
    Well hold on let me start off by saying you need to purchase a quality tire gauge in the first place. Those AutoZone/Parts store ones are VERY inaccurate. If your soooo cheap you can't spend or won't spend $25-40 on a gauge borrow a nice one at the track and see how far off your is.
    So back to the parking lot. Do a very small burnout and come back to look @ the marks. You will see weather or not the center is darker than the outsides.
    I would start @ 28 and go down a couple pounds at a time. Do this until you see a nice uniform tread contact on the ground. Record that PSI and use that when you see the track.
    DON'T drive through the water box either drive around it!! Back up and just spin the tires to clean them off and put LITTLE heat.
    Street tires DON'T like burnouts or extreme heat it will make you spin worse.
    The ? on the Mickey's is WAY too general to receive a real answer.
    What size Mickey on what size wheel?
    A pair of V-6 junkyard springs will do more for your traction than any tire with your stiff ass springs you have the rear will not squat to allow weight transfer for shit at this point.
    Germany
    Blue
    Well the mickeys are et street radials 275/40/17's on my stock wheels.
    Well I hope my car will hook up pretty good. I'm not sure how good it will even run yet, but I will post after I go on sunday.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    On the stock 8" wheels I would start @ 22 and go down slowly. On my stock 17's I managed 1.56 60's with stock convertor and it hooked best with 17.5psi.
    Germany
    Blue
    thanks for the input. I'll see where she hooks best at on sunday!
  1. Tire Pressure?
    By Orp0408 in forum Wheels and Tires
    Last Post: 10-23-2012, 05:32 PM
  2. WS-6 Tire pressure
    By Whamhammer in forum Firebird / WS6
    Last Post: 12-21-2011, 02:11 PM
  3. Question: Tire Pressure!
    By TransAmPhantom in forum Wheels and Tires
    Last Post: 06-21-2010, 11:37 AM
  4. Question: Tire Pressure for 275/50R15 MT Drag Radial Tire?
    By WS6ICK in forum Wheels and Tires
    Last Post: 12-01-2008, 01:51 PM
  5. tire pressure
    By LT1 > LS1 in forum Wheels and Tires
    Last Post: 11-07-2008, 05:33 AM
