    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    z28 emblem coming up???
    my z28 emblem in the rear of my car is pealing on the left side......what do i use to stick it back to the paint without worrying about damaging the paint????
    Senior Member
    rochester,ny
    pewter
    anyone?
    USA
    BLACK
    Z/28 LS1
    IMO you need to remove the emblem first and put 3M outdoor double sided tape on it and then re-install. Here is how I did mine:
    1) Wax the area around the emblem- 5-6 inches around it.
    2)Use painters tape and tape around the emblem at least 5-6 inches around it.
    3) Take a hair dryer and heat up the emblem-not too hot though-just hot enough so the emblem starts to move a little when you pull on it.
    4) take fishing line-about a 2 ft peice and pull it behind the emblem until the emblem is removed-if it wont work continue heating the emblem.
    5) Use wd/40 and a soft cloth to remove the sticky residue from where the emblem was. Its best to let the wd/40 soak in for a few minutes.
    6) wash the area you just cleaned with wd/40
    7) put new 3m double sided trim tape on the back of the emblem once you remove the old tape/sticky shit.
    8) install the emblem-then pull off the painters tape. *note-the painters tape not only protects the area around the emblem from excess heat from the blowdryer it also acts as a template so you know exactly where to put the emblem back on the car. Waxing the area before putting the tape on ensures no issues when removing the tape.
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    I second the 3M double sided tape thingy.
    2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
    Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
    2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
    Senior Member
    rochester,ny
    pewter
    nice..thanks guys
    USA
    BLACK
    Z/28 LS1
    No problem bro....
  1. ****WS6 Zo6 emblem pic****wut u think?
    By weberje in forum Appearance Section
    Last Post: 02-01-2008, 02:06 PM
  2. WTB- 5.7 Emblem
    By Wyman in forum Parts Wanted / Trade
    Last Post: 09-05-2007, 03:47 PM
  3. 5.7 emblem
    By Runn_WS7 in forum Appearance Section
    Last Post: 08-09-2007, 05:30 AM
  4. WS6 Emblem
    By Monster-Inside in forum Firebird / WS6
    Last Post: 02-20-2007, 03:23 AM
