Results 1 to 20 of 24
Thread: Water Pump Leaking
02-26-2008, 09:06 PM #1Junior Member
- Apr 2007
- Angleton, Texas
Black- 2000 WS6 Trans Am
Water Pump Leaking
After seeing fluids on the ground at school I drove over to a local shop to see what the deal was.... Turns out that my water pump is leaking so I need a new water pump blah blah blah they want to charge me 420 bucks to change it out and my Dad offered to pay for half of it.... But one of my friends offered to change it for free and I woudnt have to pay. So should I let my friend change it for free(he hasnt done it before) or pay half of the price and let the shop fix it and know that it is done right.
02-26-2008, 09:15 PM #2
its really really simple you can even do it just make sure you get the surface really clean. i have done it on mine yet but have done it on others
02-26-2008, 09:16 PM #3
02-27-2008, 01:10 PM #4Junior Member
- Apr 2007
- Angleton, Texas
The 420 bucks includes the price of the water pump not just the labor. So I should just change it myself I guess im going to get on the phone and cancle my appt. thanks guys
02-28-2008, 10:25 AM #5
420 is a good price from a shop for parts and labor -- if you want to bring it to my shop we could do it for a little less -- Its the Goodyear off Independence and Spring Creek in Plano -- i can give you a deal
02-28-2008, 12:42 PM #6
02-28-2008, 03:19 PM #7Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
For someplace close take it to the GM dealer off of 288 and have Scott do the work. I promise he will treat you right and is honest. Just tell him his old friend in the blue Camaro sent you (we have been friends since elementary school and I would trust him with anything).
I did not realize you were in Angleton, do you make it to the track some ? I am planning a trip there this March.
02-28-2008, 07:21 PM #8
Do it yourself. It's held on by six bolts.
03-09-2008, 02:01 PM #9
Can anyone give me a bit of a hint what it would sound like (or feel like) if my water pump ('98 LS1) were to go out ony me while driving? I see little drops coming from that weeper hole thingy, and wondering how much borrowed time I'm on.
03-09-2008, 03:26 PM #10
if its already leaking then you need to change it...just keep an eye on your coolant level and keep a gallon of water with you intill you change it.
03-09-2008, 09:43 PM #11
Thanks! I'll be changing it out on Tuesday.
I know this is probably a bone-head question, but...what it is that fails inside the water pump that causes it to leak or rupture?
03-10-2008, 12:14 PM #12
nothing you just have to change it...
03-10-2008, 04:37 PM #13
I did my own...
http://www.projectcamaro.com/forum/s...914#post221914
its the actual pump that begins to fail and you know it by the noises it makes and coolant leaking out the weep hole on the pump behind the bell. When mine went bad, I had a stuck closed thermostat and leaking pump lol...
03-11-2008, 01:07 PM #142002 Formula Firehawk
- Jul 2005
- San Diego CA
Black- 2002 Formula Firehawk
The hardest part of the install is waking up that morning the next is properly cleaning the mating surfaces
Victor
2000 z28 A4
2002 Formula Firehawk M6
03-12-2008, 11:04 AM #15Junior Member
- Jan 2008
- Rock Hill, S.C.
Silver- 2000 Z28
The usual failures are the bearing and seal. The bearing is the noise you hear and the seal leaks the coolant that you see. Through all of this, the pump may pump just fine until the bearing overheats enough to kill the impeller.
03-12-2008, 11:15 AM #16
Thanks, guys.
Had the damn pump ($250) changed yesterday. Car should be good for at least another 90,000 miles.
03-12-2008, 07:46 PM #17
03-15-2008, 03:12 AM #18
Ta Dah!
Brand new pump!
03-15-2008, 03:26 AM #19
On these threads and others I was led to believe that the weep hole(thingy) was behind the pulley-you can't see it without removing the pulley?So if you see coolant leaking the other cause may be a bad gasket which would not require replacing the pump? Does anyone have a picture of the weep hole? That would be great.
03-15-2008, 07:02 PM #20Internet Tough Guy
- Nov 2007
- Oregon
Sinister, SixGun- 2001 SS, 2002 L36 M5
i changed mine cause i was bored
and a gasket was leaking.
cost me $105 for the pump and like $8 for the gaskets, took about 45 minutes, only cause the gf wouldnt stop calling.
decided to paint it before the install too...
Water leaking on floor of my GTO
By Roman nj. in forum GTOReplies: 6Last Post: 10-03-2011, 01:16 PM -
Question: Water pump is leaking
By JoshieDoom in forum External EngineReplies: 5Last Post: 03-10-2009, 03:14 PM -
Help: water leaking from hatch
By sd1971 in forum General HelpReplies: 3Last Post: 02-09-2009, 06:19 PM -
Do electric water pumps pump enough water for daily use?
By xinthenight in forum External EngineReplies: 6Last Post: 08-02-2007, 09:04 PM -
Water is leaking inside my car
By BLKbandit98 in forum Firebird / WS6Replies: 4Last Post: 03-20-2006, 08:05 AM
