Results 1 to 20 of 32
Thread: Hub Assembly
02-25-2008, 01:27 AM #1Impounded
- Oct 2007
- Beaver Dam KY
Hub Assembly
Would it be wise to replace the front hub assemblies at 150xxx?
02-25-2008, 02:27 AM #2Senior Member
- Nov 2006
- Indianapolis
No noises, no looseness means spend your $$$ elsewhere.
02-25-2008, 02:39 AM #3Impounded
- Oct 2007
- Beaver Dam KY
Ill probably replace them when I get tubular a-arms
02-25-2008, 06:31 AM #4
Well, to me it's one of those things that fall under maintainance. After so many thousands of miles you can't help but wonder how those bearings are doing. Since they are sealed and non-servicable (thanks GM
In any case,,,it's a judgement call really. Leave it till it breaks is a scary approach if you drive your car any distance. I would hate to have my car 2,000 miles away when a wheel bearing or some other wear/maintainance item decides to take a crap because I was to lazy or cheap to go over some things, especially when I require these cars to haul my family around and be safe.
Myself???? Personally at 150,000 miles I'd be putting a pair of them in for piece of mind.
02-27-2008, 11:08 AM #5Member
- Tulsa,OK
Quick Silver- 2002 Z06
I have mixed feelings on this. I'm really into preventative maintentance but I also don't like spending money on things just because they "might" break.
Anyone know how much they cost. If you could get a set for $150.00 - $200.00 I would do it. I'm sitting at 190,000 on both my birds and have not replaced them.
It has been on my mind as something that probably should be done. Both cars have had to have rear end bearings replaced and a shaft or two. I'm amazed the front have not had any issues at all.
While your down there probably a good time to replace tie rod ends, atleast the outer ones.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
02-27-2008, 12:34 PM #6
02-27-2008, 01:05 PM #7Member
- Tulsa,OK
How much where they?
02-27-2008, 01:26 PM #8
02-27-2008, 04:26 PM #9
my mechanic said that my left front was bad, you say you paid 100 per. where did you get them and how hard where they to install any special tools involved
02-27-2008, 04:33 PM #10Impounded
- Oct 2007
- Beaver Dam KY
I know it takes 4 bolts to get them off... looks like cake
02-27-2008, 06:26 PM #11
good preventative maintenance, but usually those things will start to squeal when they are on their way out, and will howl like a bitch before they actually crap out.
if you do alot of highway driving, probably a good idea so you dont get stuck somewhere, but if you just boot around town... wait until they start to make noise.
02-28-2008, 05:07 AM #12
got them off ebay no special tools but to make it faster I just took off the caliper brakcet first and slid everything off the rotor. Saved me alot of time. I will probably get bashed for that but it worked for me. There was no squealing I checked mine by jacking it up and trying to wobble it up and down. If it pops from left to right its a bad tie rod. up and down bad hub assembly.
02-28-2008, 08:26 AM #13Impounded
- Oct 2007
- Beaver Dam KY
Ive got both....unfortunately...
02-28-2008, 08:29 AM #14
02-28-2008, 09:13 AM #15
screw u the passanger one was so bad we had to get a hammer to get it out... it was rusted on... i'd do it!
02-28-2008, 12:10 PM #16
Personally I think the sealed hubs are much better than traditional wheel bearings ever were. I'd much rather have the hubs last the life of the vehicle, rather than pay $50 for a set of wheels bearings and seals every 50,000-80,000 miles as with a traditional wheel bearing setup. Not only that, but regular wheels bearings can be a real pain in the ass to install (especially 4WD vehicles), whereas these just bolt on with 4 bolts.
If you inspect the hubs, and they have no play in them and turn smootly without any noises, I see no reason to replace them. Its extremely unlikely that their condition would degrade fast enough to cause a breakdown, they wear out gradually.
02-28-2008, 02:36 PM #17
02-28-2008, 05:24 PM #18
I don't agree,,,if you're only getting 50-80,000 miles out of a traditional wheel bearing setup then someone isn't packing the bearings properly with grease and/or not setting the preload properly.
I have plenty of old cars out here that say otherwise
Not to mention much cheaper to repair if the time ever arrises. I just think people have gotten lazy over time.
As far as breaking down gradually??? Well I'll try telling the car that next time I'm 2,000 miles away from home,,,,LOL
02-29-2008, 02:20 PM #19Senior Member
- Nov 2006
- Indianapolis
Allright, I meant that I agree with the no maintenance issue about sealed wheel bearings. The old school kind are a pain in the ass. And the sealed bearings usually give (in my experience as a mechanic) more warning before they fail. Customers come in long before total failure because of the noise. The old school bearings would come in on the wrecker a lot more often than the new style. And yeah, the old ones should last longer than 80k usually.
03-09-2008, 08:22 AM #20
This is a few weeks old, but I am in the process of finding a good set of these. I've bought auto zone bearings and they are JUNK! Napa has lifetime warranty on their bearings and their parts are usually better - only things is they want $240 each!
GM usually has a better part as well, being oem and whatnot, they are around the $200 each, but not warranty.
I can't wait to drop that kind of money...... I am worried that mine are worn from being old and sitting. My car came to me with only 28000 miles on it, so I am assuming it wasn't driven much. Sometimes the sitting can get to a car.
Engine Assembly Tips Part 2 - 16 More Engine Assembly Dos An
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-11-2013, 05:00 PM -
Wanted: Factory Air Box Assembly
By ls1kid20 in forum Parts Wanted / TradeReplies: 0Last Post: 07-18-2013, 10:11 AM -
PCV Assembly - A few questions...
By nyarsulik in forum Firebird / WS6Replies: 12Last Post: 03-30-2010, 05:29 AM -
WTB LT1 rotating assembly
By DW2000TA in forum Parts Wanted / TradeReplies: 0Last Post: 12-09-2007, 12:57 PM
