Results 1 to 10 of 10
    I Fixed Da Rear jimbo98z's Avatar
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    Exclamation Wet Floor Boards... Need Help QUICK!
    Alright, I have a 98 Z with about 100k miles and it has been garaged ever since I have owned it. Now that I am in college, I don't have a garage to store it in, so it sleeps outside. My problem is that now, every time after I go to drive the car after a heavy rain, the floorboards are soaked. There is enough water that the first time it happened, I thought I had left a window cracked. I know for sure that it's not the t-top seals. There is a gap between the window and the seal on the lower 4-6 inches of the glass. I'm thinking it's one of three things:
    1. The seal is bad (it feels a little stiff, but its not cracked or anything, and it's probably the original seal)
    2. The door is starting to sag on the hinge (don't know if this happens)
    3. The windows are off track a little (had this problem with my accord)
    Just wondering what you guys think is the most likely cause.
    Thanks in advance,
    Jim
    Junior Member ZedTwoEight's Avatar
    L.A.
    pewter
    1999 Z28
    best way to find a leaky window or door seal is take it to a window shop...they should have a little smoke machine that they'll use to find bad seal spots...otherwise, you'll be wasting a lot of your time.And just why are you sure it's not the t-tops? that would be the most likely culprit.
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    I'm pretty sure its not t-tops because the ceiling in the area around the t-tops is bone dry. I just hate to take my car to someone and pay them to do what i could do. Basically, i was just seeing if somebody knows what it would most likely be.
    Also: I know where it's coming from: the 4-6" strip where the gap between the window and the seal is. My question is more what would cause that gap to be there.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    worn weather stripping...window/door out of alignment. Hows the alignment spacing around the door...is it all even? My guess is that the window itself is out of alignment.
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    the alignment of the door seems even all the way around. i'm with you in thinking that its just the window, because the seal doesn't seem bad, and i've been taking care of them (silicon spray about once a month). I'm going home for Christmas this weekend so i'll have a chance to work on it then. The passenger side window is a little slow so i was thinking it was about time to replace the motors anyways.
    Smooth Operator 98LSGUN's Avatar
    Atlanta
    1998 Camaro SS Vert M6
    Sit in the car and have someone spray the car with a hose, this way you will know exactly where the water is leaking in and where it's not...
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    Ok, this is what I'm saying. I know exactly where the leak is coming from. It's leakng where the window seals against the weatherstripping on the rear for the bottom 4-6". There is a gap big enough to poke a key through for that 4-6". This is definately where the leak is coming from.
    My question is: why is that gap there, and how do i fix it.
    Pa
    2006 TrailBlazer SS
    Just want to get in on this thread I have the same problem
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Quote Originally Posted by jimbo98z
    Not sure...here's a link that'll help you disassemble the door though. Look for anything broken. http://shbox.com/page/windowmotor.html
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    i went out and took a look today, and it looks like the doors may be sagging and need to be adjusted on the hangers. has anybody hung a door on one of these cars? i know its a pain on anything, but is it particularly hard on camaros?
  1. blogs and boards
    Last Post: 03-31-2009, 08:21 PM
  2. New guy on the Boards with a GM truck
    By Gibs07TBSS in forum GM Trucks
    Last Post: 12-20-2008, 07:47 AM
  3. ranking boards
    By jimmybling31 in forum Request and Feedback
    Last Post: 02-24-2008, 09:26 AM
  4. Any good SUV boards out there?
    By Pulse Red GTO in forum Almost Anything Goes
    Last Post: 02-23-2007, 06:59 AM
  5. I miss the old boards
    By Scoop531 in forum Request and Feedback
    Last Post: 10-01-2005, 01:02 PM
