Results 1 to 2 of 2
    Junior Member topgun1851's Avatar
    Virginia Beach, VA
    '02 WS6 Procharged 9psi
    Boosting a 427 LS2?
    Will it be safe to run a 4.125 bore in a LS2 sleeved block with forced induction, 10-15psi. It will also include a 4” crank making a 427. Its either this or keeping the 4” bore with 4” crank 402, 10-15psi. But I really want to do the 427. Aiming for 700-800rwhp.
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    Quote Originally Posted by topgun1851 View Post
    Well, it can be boosted as long as the compression is good, but any time you start messing with the bores and going bigger something has to give eventually. To get the sleeves in there you have to have more material taken out of the block. Go with a 402, you can get the HP you want with that. What you really have to ask yourself is how long do you want the motor to last? Stretch the motor to a 427 and throw boost on it and it wont last 100K miles. Well, for that matter you can't expect a 402 to do the same.
  1. Help: A problem after boosting
    By CAMSS2002 in forum Forced Induction
    Last Post: 08-05-2009, 09:36 PM
