Results 1 to 3 of 3
Thread: blinker issue
08-13-2005, 12:43 PM #1Junior Member
- texas
artic white- 2000 SS LS1
blinker issue
so i was driving along and tryed to use my right blinker and i noticed it would come on but wouldn't blink. So i went to auto zone and turned all my lights on and checked all my lights, sure enough, the front right blinker was out. So i got a replacment bult and replaced it(the old bulb was blackish). Then i tested the right blinker and it still will not blink... The new bulb does light up but just doesn't blink. All my other lights are working, what am i missing here?
I thought all i needed was to replace the bulb that was burned out and everything would be fine but now i duno what to do. Any help is appreciated. thx
08-13-2005, 12:46 PM #2Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Check to see if there is a ground wire loose. That would make it do that. I can't remember if there is a ground wire on them or not.
08-15-2005, 07:49 AM #3greasy-chickenGuest
Re: blinker issue
Also check to make sure you got the right replacement bulb. The front light is a blinker and a running light so it needs two filiments. Check the bulb socket as well. Besides my TA I have a GMC Yukon. The blinker bulb in the rear tail light was not working even with a new bulb. I discovered it was the socket that was bad. I had to order a new socket plate and that solved the problem.
idle issue.. may be tune issue.. help?
By okiels1 in forum General HelpReplies: 2Last Post: 12-07-2016, 02:17 PM -
pvc issue... vacuum leak....tune issue?
By okiels1 in forum General HelpReplies: 3Last Post: 03-05-2016, 09:10 AM -
Help: tranny issue think it might be planetary issue
By nerisls1 in forum Automatic TransmissionReplies: 6Last Post: 03-05-2009, 09:32 PM -
Blinker Issue
By DB69TA in forum Stereo and ElectronicsReplies: 4Last Post: 11-10-2007, 05:27 PM -
Blinker Issue
By bwinch in forum General HelpReplies: 0Last Post: 07-30-2007, 05:15 AM
