Results 1 to 3 of 3
Thread: soooo on my VIS
    down with the lot lizards blackhawk01's Avatar
    Pensacola
    2001 Camaro SS A4
    soooo on my VIS
    I have this
    CLAIM HISTORY
    R.O Date R.O Number Type Labor Operation Odometer Reading
    11/03/2003 797194 # T2020 - TOWING 33499 miles
    11/03/2003 797195 # Z8016 - ROADSIDE GONE ON ARRIVAL 33499 miles
    06/12/2003 115511 # C1421 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - LEFT - REPLACE 29077 miles
    06/12/2003 115511 # B4156 - OUTSIDE REARVIEW MIRROR REPLACEMENT - LEFT SIDE 29077 miles
    06/12/2003 115511 # B9627 - LAMP ASSEMBLY, EXTERIOR - SIDE MARKER FRONT - LEFT - REPLA 29077 miles
    04/22/2003 113040 # K2753 - GEAR - 2ND SPEED GEAR - R&R OR REPLACE 22909 miles
    03/04/2002 038696 # J4355 - CRANKSHAFT POSITION SENSOR REPLACEMENT 10493 miles
    03/04/2002 038696 # N0528 - BULBS, LAMP - EXTERIOR - REPLACE 10493 miles
    02/18/2002 038314 # N6602 - WIRING AND/OR CONNECTOR - CHARGING/STARTING/BATTERY - REPA 9630 miles
    02/18/2002 038314 # J1000 - PAN AND/OR GASKET, OIL - REPLACE 9630 miles
    02/18/2002 038314 # F2003 - COVER AND/OR GASKET, DIFFERENTIAL - REAR DIFFERENTIAL - RE 9630 miles
    12/27/2001 036759 # R0950 - RADIO REAR SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 7103 miles
    12/27/2001 036759 # C1420 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - RIGHT - REPLACE 7103 miles
    12/27/2001 036759 # C1421 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - LEFT - REPLACE 7103 miles
    12/10/2001 036333 # J6372 - SENSOR, OXYGEN (ENGINE CONTROL) - REPLACE 6878 miles
    12/04/2000 A30013 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    are these bad? im more worried about the roadside towing...has the bitch been wrecked? I know that someone got arrested going 120 in it before
    Impwnded Smkn_TA's Avatar
    Davenport, Iowa
    Bright Red
    1999 Trans Am Ws6
    I've replaced crank position sensors on 5 cars, and on none of them was it the thing that was wrong. If you go to start the car, it doesn't turn over or even try to start, battery tests okay, alternator is good, I always think it is the stupid crank sensor.
    Sideswipe something and knock those off or what?
    Pensacola
    2001 Camaro SS A4
    i was thinking either that or running off into a ditch, i think my car was abused,, seriously
  1. soooo
    By GTP231 in forum Political / Debate Forum
    Last Post: 08-12-2010, 08:36 AM
  2. Soooo owned!!!
    By blackSS01 in forum Almost Anything Goes
    Last Post: 07-21-2010, 12:01 PM
  3. SOOOO, I have a question??
    Last Post: 09-13-2009, 06:46 PM
  4. Im SOOOO PISSED
    By 2000T/A Guru in forum Firebird / WS6
    Last Post: 06-22-2007, 01:39 PM
