Results 1 to 20 of 22
Thread: Some photos of my SS vert
02-18-2008, 08:37 PM #1member since Aug 98
- NM
Took my car out along with my friend's 94 Cobra and did a quick photoshoot. Here are some pics:
02-18-2008, 10:44 PM #2
nice vert , i like those ZR1s
02-19-2008, 12:37 AM #3Member
- May 2007
- Seattle
Jetstream Blue Metallic- 2008 Z06 Corvette
I like the number 3 shot of your car, it almost looks as if your car was superimposed onto a black and white background. The color of your car really stands out in that particular shot.
02-19-2008, 01:38 PM #4
Very nice pics, even made the Mustang look good. What camera are you using?
02-19-2008, 01:44 PM #5Consumer of kraut
- Dec 2006
- Jenks/Tulsa
Light Pewter Metallic- y2k 8-cylinder catfish
Great photos!
2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
02-19-2008, 01:46 PM #6Just a souped up sunfire.
- Jun 2007
- Parma Heights, Ohio
SOM- 99 Trans Am
Some good photoshoppin there. Amazing pictures too. Get some new headlights and that thing is done cosmetically. Beautiful car.
02-19-2008, 02:50 PM #7
2018 Tahoe - Silver - OEM
02-19-2008, 03:46 PM #8member since Aug 98
- NM
Thanks! I'm using a couple D200s. With those shots I used a Sigma 10-20mm wide angle and a Sigma 70-200 f/2.8 lens. I'll get a model to pose next time. Or I might just save those for next year's calendar!
02-19-2008, 04:02 PM #9
those pics are awesome! car looks great too.... but i may as well be the first to say that you need to slam that baby down! got the 4x4 look goin on.
02-19-2008, 04:08 PM #10member since Aug 98
- NM
Does anyone know how low I can go with the 17x11s and 315s in the rear without rubbing anything?
02-19-2008, 05:31 PM #11Senior Member
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
i have the prokit and the same size width as you just in 18's. i had no outer fender rubbing issues just slight inner, tapped it in with a hammer and seemed to help until i really got into some corners, then i put a slp panhard and slp lca's and the problem was fixed, if i was you i would lower my car get the umi lca's and panhard and relocation brackets, then you will be set, looks damn good btw, amazing pictures, i think personally a gloss black grille from slp and some shined up lights, your good as gold, clean stang btw not bad for a 95
02-20-2008, 07:45 PM #12
02-20-2008, 07:50 PM #13
02-21-2008, 07:49 AM #14
02-21-2008, 07:53 AM #15
Make sure you submit one of those for COTM next month.
Great pics.
02-21-2008, 08:03 AM #16
02-21-2008, 09:07 AM #17
02-22-2008, 10:33 AM #18Junior Member
- Dec 2006
- Canada
dood clean out those headlights... otherwise the car looks sikk
02-24-2008, 04:59 AM #19
I agree pic #3 is pinup material
If I could do it over again, I would have held out for SOM, great color and great car
02-24-2008, 06:24 AM #20
I had problems going up inclines at an angle. Would rub the inner fenders pretty good and I had full rear suspension with the exact rim (well mine are chrome ZR1's) and tire(different brand though) as you. If you lower it without an adjustable PHR though it will rub inner pass and outer driver side even after touching up the inners with a hammer. Cut 2 tires before I lipped it and switched from a non adj to an adj PHR. But I have heard from others otherwise, no 2 act the same even with the same combo it seems.
G12 Photos >>>>
By 01pewterz28 in forum Almost Anything GoesReplies: 7Last Post: 05-27-2008, 07:03 AM -
Adding sub to stock vert T/A (Install guide especially for Vert Owners)
By x2qwk4ux in forum ConvertibleReplies: 6Last Post: 06-13-2006, 01:46 AM -
By x2qwk4ux in forum Stereo and ElectronicsReplies: 2Last Post: 02-11-2006, 06:37 AM
