Results 1 to 1 of 1
    Member tici's Avatar
    Zurich - Switzerland
    1998 M6 vert TA
    How to recognize a "thick" ring?
    Hi,
    I just received a new ring and pinion set.
    The brand should be Yukon but looking at the design it's probably a Richmond.
    However...
    It should be a 3.42 set for a series 2 carrier = thick ring.
    The set wasn't in the original box and there is no parts numbers.
    Is there a way to be sure it's a thick ring?
    The ratio is OK (12 x 41 teethes).
    The distance between the flat surface of the ring and the outer edge of the teethes is 31 mm or 1.22 inches. Does it help?
    There is a "64" stamped on ring + pinoin (?)
    Do you still have your stock 3.42 series 3 gears? Could you please post a pic of the ring? maybe it helps to understand.
    here a pic of mine with a pinion bolt and a new crush sleeve to compare.
    Thanks!
  1. Hussein Obama: Opponents to Iran "Deal" are "Crazies"...
    Last Post: 08-26-2015, 11:11 AM
  2. Hard Left in Knots over "Wacist" Prism of "Cat Call" vid
    Last Post: 10-31-2014, 04:07 PM
  3. Ring Brothers 1970 Chevrolet Camaro "Diversion"
    By Ed Blown Vert in forum Classic Muscle
    Last Post: 11-04-2011, 04:40 AM
  4. Change Carrier or Use "thick" gears
    By HasselZ28 in forum Drivetrain
    Last Post: 08-19-2007, 06:25 PM
  5. SLP/GM Ring & Pinion, 4.10, Gear Set 7.5" & 7.625" Differential
    By Stealthperf.com in forum Parts For Sale / Trade
    Last Post: 10-18-2006, 09:01 PM
