    Michigan
    2002 WS6 Trans Am
    Stock gears, is it 3.23?
    on a 02 WS6, A4?
    Yes
    Painted manta stripe
    Feb 2008
    Cedar Falls, Iowa
    2001 Firebird Formula
    rpo code for 3.23 is GU5
    2-Legit-2-Quit bgable's Avatar
    Cville,Indiana
    IBM
    2006 Pontiac GTO
    is there any way to get your rpo code if alls you have is the vin number?
    Senior Member t-rock's Avatar
    pocola oklahoma
    2002 firehawk 94 Z28
    auto's 3.23 man 3.42 i guess if you have access to a gm data base to answer your last ques.
    Feb 2008
    Cedar Falls, Iowa
    Quote Originally Posted by gable2000ta View Post
    there should be a rpo code sticker inside of your door...on the jam part. it should be the bigger one with more numbers/letters on it. examples are AR9, CC1, GU5 etc...i dont think gm puts all the codes on this one sticker since the rest of the options are standard equipment for the most part. i think theres a couple more places where the rpo sticker is hidden...i dont know where tho.
    go to a gm dealer, give them your vin and someone will print out the record of your car. itll be 3 pages or so with where and when your car was built and the options the car was equipped with.
    Member vannatte's Avatar
    Noblesville, IN
    1998 Pontiac Trans Am A4
    If its a true WS6 auto it can only have 3.23's. A manual, regardless of whether it is a base T/A or WS6, has 3.42's. Base model automatic T/A's will either be 2.73 or 3.23, you won't know without checking the RPO code on the door sticker. As stated earlier
    GU5=3.23 and GU2=2.73.
    1998 Trans Am, A4, SLP Loudmouth I, US Exotics WS9 ram air hood, Volant intake, 3.23's, 70k miles
  1. For Sale: Stock 3:42 Gears
    By Dillard99 in forum Parts For Sale / Trade
    Last Post: 02-26-2008, 11:30 AM
  2. stock gears
    By derbs in forum LT1
    Last Post: 04-01-2007, 08:05 PM
  3. Stock Gears
    By chrombs13 in forum Drivetrain
    Last Post: 10-28-2006, 07:38 AM
  4. what are my stock gears?
    By z28jerad in forum Automatic Transmission
    Last Post: 08-02-2006, 12:42 PM
  5. Stock 2.83 gears to 3.73 gears?
    By 97formula in forum Automatic Transmission
    Last Post: 11-20-2005, 08:36 AM
