Results 1 to 17 of 17
Thread: Magic stick 4 cam help
02-16-2008, 08:06 AM #1
Hey guys I was just curious what gear everyone is running and fuel and timing setups would help.
02-18-2008, 05:43 AM #2
I have a MS3 which is just a tad smaller . Gears are 4.11's, 3600 stall, couldn't tell you the timing specs as someone else did the the tune. Just TR55 plugs and MSD superconductor wires nothing special there. As far as fuel setup I have a racetronix 110 pump and 42 lb injectors.
02-18-2008, 07:06 AM #3
02-18-2008, 09:15 AM #4
- Feb 2006
- MD
I'm running the MS4, but timing and fuel are specific to each particular engine and will not be the same between ANY 2 vehicles. Works well with my 4000 stall and 3.73s.
02-18-2008, 05:22 PM #5
02-19-2008, 05:59 AM #6
- Feb 2006
- MD
02-19-2008, 07:28 AM #7
- North Olmsted, OH
Navy Blue Metallic- 2000 Camaro Z28
3.73 here (M6 though), 42# injectors otherwise stock fuel.
2000 NBM Camaro Z28
Mods:
SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
02-19-2008, 07:14 PM #8
I have 4000 stall, Lt's, x-pipe, lid, pulley, and 85mm tb, and soon a ms4 just trying to get the gear thats going to get the best time.
02-20-2008, 04:17 AM #9
- Feb 2006
- MD
That's easy... 3.73 for a street car, or 4.10s for a track car and a broken 10 bolt
02-20-2008, 01:13 PM #10
Don't say dirty stuff like that, Its handled a 100 shot off the line so I hope it holds up for at least 3 or 4 trips if not I have another 10 bolt to go back in
1998 WS6 Trans Am
02-20-2008, 05:21 PM #11
i have a ms4 cam with a m6 with 4.30 gears 12 bolt with the 255 pump and hot wire kit with 30 lbs injectors dart heads fast 90/90 combo merize ls1 pump slp under drive pulley crane gold rockers msd coils car dyno at 26 degress of timing 13.50 on the fuel curve went 467 on motor 428 torque with the 150 shot went 576 on motor 533 torque the motor is built h beam rods arp studs on bottom and top with weisco pistons car went 11.38 @119 on motor 10.68 @127 on the bottle and gets 24 mpg on the highway drive 100 miles evevy day cars weighs 3630 with me in it
02-21-2008, 04:26 PM #12
The MS4 is a nasty fucking cam. Its gotta very mean chop to it also. Personally, i would never get an MS4 (no offense to MS4 owners) The cam is WAY to big and is not good for a DD, although some ppl manage. It's a peak power cam and has no under the curve power. All the power is gonna kick in late and pull like a train. How often are u gonna take ur daily driver past 6k? I have been in an MS4 WS6, and at first i was like "wtf, i thought this thing was cammed" once the revs shot past 3.5k i thought the car was gonna fly away. Lot of ppl get the MS4 becasue they see dyno sheets of ppl making like 70whp on a cam only car. Dont go by dyno numbers or the highest hp rateings. Bigger isnt always better.
02-21-2008, 05:50 PM #13
Well its not a DD so I want as much gain as I can get to run the best #'s.
02-22-2008, 02:59 AM #14
02-22-2008, 07:04 AM #15
- North Olmsted, OH
Ditto Here. Also the tune makes a big difference in the low end, Though the cam does wake up after 3000 and pulls like theres is no tomorrow until redline.
02-22-2008, 08:49 AM #16
02-22-2008, 11:05 AM #17
Love it wouldn't think twice about doing it again. With a tune on these engines the typical voodoos of the 4.10's don't apply. If you bump your RPM's to match the cam specs in the upper 6's almost 7K (mine was 6800) you shouldn't be going into overdrive before crossing the traps which is what most advised against 4.10's in the first place, going into OD WOT.
Who's using the magic stick 4
By stunna p in forum Internal EngineReplies: 18Last Post: 03-25-2010, 07:35 PM -
fs: magic stick 3 cam
By adam0321 in forum Parts For Sale / TradeReplies: 14Last Post: 09-30-2009, 03:11 PM -
Magic Stick
By 02fbody35th in forum Internal EngineReplies: 15Last Post: 05-15-2009, 01:57 AM -
WTB magic stick v.3 cam
By miller456 in forum Parts Wanted / TradeReplies: 0Last Post: 12-16-2007, 08:39 AM -
224, 228 magic stick?
By Lucas in forum Internal EngineReplies: 14Last Post: 01-12-2007, 12:49 PM
