Results 1 to 20 of 22
Thread: What gain?
    Kenne-Bell Killer Cayenne97's Avatar
    Lake Tahoe, CA
    Cayenne Red, Pewter
    '97 Z28 1LE #53, '02 WS6
    What gain?
    I asked this question in the automatic transmission section with no luck. I just recently purchased a '93 Formula for next to nothing. It's my first A4 car, and it's basically stock except for a cold air intake, 1LE elbow, 160 stat, cat-back and single 3" cut-out before the muffler. The car makes good power from a roll, but last night at the track I found it to be pretty sluggish off the line with the exhaust open (cap off). It didn't take me long to figure out that 1600-rpm launches with the stock converter just ain't gonna get it done. With the exhaust open it doesn't begin making any real power till around 3000-3200rpm.
    My next step is to order a Yank 3200-stall which will put me right around where my powerband begins. My question is what should I expect for a gain, considering good traction and the stock 3.23 gears on street tires?
    Aug 2006
    Missouri
    94 Camaro Z28
    With a proper-matching stall, most people report a drop in a couple tenths off their ET's.
    Lake Tahoe, CA
    Cayenne Red, Pewter
    Quote Originally Posted by BlackLT1Z28 View Post
    See that's the thing. I hear .2 from some people, then others will tell me it's more in the area of .4 tenths. I don't know which claim is more accurate?
    Aug 2006
    Missouri
    94 Camaro Z28
    Does it really matter how much, as long as there is an improvement? As long as you get a gain with the stall that you need/have, what would be the problem? Not everyone is going to see the same improvements.
    Detroit
    By adding the stall you will see some improvement not sure how much. It all depends on your other components. But like Black said at least it is an improvement.
    Jay
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Another cool feature of the stall is you can snarl at cars when your cruising in the city without gaining speed. It's fun to do at imports and Mustangs.
    Member 35thz28camaro's Avatar
    mobile
    2002 z28 camaro
    Quote Originally Posted by Cayenne97 View Post
    my 3600 stall will be in next week i will let you know how much i gain
    Lake Tahoe, CA
    Cayenne Red, Pewter
    Quote Originally Posted by 35thz28camaro View Post
    Great. I was wondering if I should have gone as high as 3600, but I think 3200should be enough. You've got an LS1, so 3600 is perfect. Let me know your results!
    Catfish for Breakfast Bobby97SS's Avatar
    Austin, TX
    97 SS
    Stall speed ratings are only approximate. Put that 3200 behind 1000 lb ft and it will probably stall at 4000.
    Feb 2008
    Cedar Falls, Iowa
    2001 Firebird Formula
    are u sure that u have 3.23 gears? i thought only t/a's got 3.23 in 93. i have a 93 formula that is stock with 2.73 gears. this would explain why your car is slow out of the hole....they got 2.73 gears for highway cruising. i know what u mean by good power from a roll...but out of the hole it isnt the best. put the car up and take the gear housing cover off....count the teeth on the gears....small one should be 15....the bigger one 41. take 41/15=2.7333rep......this is the only 100% way to know your gear ratio. i could be wrong, but just check to make sure. u should go with 3.42 instead....ull notice a difference in acceleration and itll still be all right on fuel economy.
    Aug 2006
    Missouri
    94 Camaro Z28
    Or, instead of counting teeth, you could look at your RPO codes.
    Feb 2008
    Cedar Falls, Iowa
    stickers are not 100%.....the only sure way is to inspect the vehicle
    mobile
    2002 z28 camaro
    tested my 3600 stall for the first time last night, i picked up .3 in an 1/8 mile
    Lake Tahoe, CA
    Cayenne Red, Pewter
    Good gain! I installed the stall about 2 months ago and wen't from a best of 14.02 to 13.71. I've since added Motive 3.90 gears, Level 10 shift kit, JET Billet 2-1 servo, Strange hardened axles, BFG 255/50 Drag radials, Eibach Drag launch springs & Subframes. The car is snappy as heck off the line. Have yet to hit the track again, but i'll post numbers as soon as I do.
    mobile
    2002 z28 camaro
    what was your 60" mine was 1.67, 7.39 1/8 mile time, my mods are LT, lid, 3600 stall, 373's, flowmaster; we dont have a 1/4mile track in my area
    let the F-Bodies roll jimmybling31's Avatar
    hixson tennessee
    94 camaro z28
    holy shit. how did you get that time out of it? with those mods I would expecct around 8 flat at the best. dang. good job.
    Lake Tahoe, CA
    Cayenne Red, Pewter
    My 60-ft was 1.97. That's a heck of a 60 you got there! Are you on drag radials?
    mobile
    2002 z28 camaro
    Quote Originally Posted by jimmybling31 View Post
    my car ran 8.55 stock, after 373, lid, and flowmaster went 7.97, after LT went 7.62, after 3600 stall 7.39
    mobile
    2002 z28 camaro
    i am runnig hoosier DR's
    Lake Tahoe, CA
    Cayenne Red, Pewter
    Cool. I've got Nitto 555R's on my other car, and BFG Dr's on my Formula daily driver.
    97 Z28 1LE #53 11.08/122.84 N/A, 9.82/131.06 150-shot
    02 WS6 M6, STOCK H/C/I, 3189 lbs., 11.77/113.02 (1.59 60')
    08 Mercedez C63 AMG, FOR SALE!!!
    http://www.ls1.com/forums/showthread.php?t=108586
  1. Hp Gain
    By t5munoz in forum Member's Rides
    Last Post: 03-02-2010, 10:47 AM
  2. How Much HP gain with CAM?
    By 2001ws6 in forum Internal Engine
    Last Post: 06-22-2009, 08:44 AM
  3. How much hp & tq gain?
    By WS6ICK2K in forum External Engine
    Last Post: 04-05-2008, 05:14 PM
  4. How much hp do you think i'll gain?
    By sfletch2000 in forum Firebird / WS6
    Last Post: 03-13-2007, 12:18 PM
  5. What will I gain?
    By Deneau Valteau in forum GTO
    Last Post: 12-21-2006, 10:10 AM
