Results 1 to 18 of 18
Thread: Brake Rotor Question
02-13-2008, 08:31 AM #1Junior Member
- Nov 2005
- Georgia
SUNSET ORANGE- 2001 CAMARO SS
My front rotors are warped and I want to get new ones. Does anyone have a recommendation of what kind to get? I don't want the high-dollar cross drilled ones, but the slotted ones might be OK for me.
Any ideas on what kind and where to get them?
Thanks,
Eddie
02-13-2008, 09:19 AM #2Senior Member
- Sep 2005
- rochester,ny
pewter- 2001 z28 lingenfelter 383
02-13-2008, 10:23 PM #3Crazy Canuck !
- Jun 2002
- Montreal, CANADA
same advice.
Eugenio_SS
02-13-2008, 10:46 PM #4
+1 they are good rotors
02-14-2008, 10:38 AM #5
02-14-2008, 02:21 PM #6
i also say thats good, R1 concepts are also good
thats what im rockin!
02-14-2008, 08:46 PM #7Crazy Canuck !
- Jun 2002
- Montreal, CANADA
Demon, love your avatar... teeth from the Towing
02-14-2008, 09:01 PM #8
thanks! I kinda stole it from a member off of F-quick...
Strobin SS...shhh dont let him know that!
02-15-2008, 07:04 AM #9
I hear the Autozone replacements are decent.
02-15-2008, 05:58 PM #10
I've read that a lot of people get the Autozone ones b/c they have a lifetime warranty and they just replace them about once a year or so. Whether that is true or not, I'm not sure.
02-16-2008, 07:18 PM #11
I went with EBC drilled and slotted (EBC-Combo/$299.99) and they are great, my friend went with the Rotoworks (ROTO-PKG/$169.99) and has no complaints he loves em. And thats for all 4 on both packages. http://www.ws6project.com/user_stor/...ath=235_66_301
So high dollar shouldn't be too much of an issue and you can have nice lookin rotors that are actually effective and reliable especially compared to stock.
02-16-2008, 09:24 PM #12Crazy Canuck !
- Jun 2002
- Montreal, CANADA
effective means not getting drilled... you need the mass and contact surface area.
02-16-2008, 09:33 PM #13
go to O'Reilly's and tell them that autozone has rotors that are cheaper.......they will price match it. You will get a little better quality rotor cheaper that way
just double check to make sure autozone is still cheaper..........I did this a
couple months ago
02-16-2008, 09:48 PM #14
true to an extent. I meant dimpled and slotted. That is what mine are. Drilled all the way through supposedly weakens the integrity of the rotor. Thats why I went with the EBCs. the slots and dimples do not go through the rotors, but still provide a cooling effect (especially under hard applications and/or repeated applications) to make them last longer than normal rotors.
02-16-2008, 10:06 PM #15Crazy Canuck !
- Jun 2002
- Montreal, CANADA
no cooling effect advantage on slotted rotors... only advantage, is that it gets rid of any small dirt that can be found between pad + rotor, especially if under dirty/wet conditions.
02-16-2008, 11:01 PM #16
Yeah, drilled and slotted are mostly appearance and do not help performance.
02-17-2008, 01:55 AM #17
If ya'll say so. I will stick with my dimpled/slotted set and not worry so much about cracking like I have seen stock rotors do.
02-17-2008, 08:19 AM #18Crazy Canuck !
- Jun 2002
- Montreal, CANADA
the stock ones are plain shitty.
If you get the same you have just slotted or plain, it's better than drilled. slotted are good... not drilled.
Question: Brake rotor size question
By davidz28 in forum Suspension and HandlingReplies: 2Last Post: 02-07-2012, 01:44 PM -
Rotor and brake help!
By NJ2002WS.6 in forum Firebird / WS6Replies: 33Last Post: 09-13-2008, 04:30 AM -
Warped Brake Rotor-Which One?
By silverbird22 in forum General HelpReplies: 10Last Post: 03-09-2008, 05:01 PM -
emergency brake question when running C5 rotor
By CorvetteZ06C5 in forum Camaro / SSReplies: 2Last Post: 07-22-2007, 07:04 AM -
13 inch brake rotor on WS6
By darkness in forum General HelpReplies: 4Last Post: 05-16-2006, 11:27 PM
