    weberje
    Guest
    Painted my intake...
    Got the intake done. Simple duplicolor rattle can. I've painted aircraft before, but nothin much like this (glossy). Very pleased with the result! I just went with a gloss black, b/c I'm planning on doing fuel rail covers color-matched red. Second pic, you can see has a little dust on it. That's collected after curing- waiting to let it cure a bit before I install.
    Here's the pics:
    Member Firebird Phoenix's Avatar
    Feb 2007
    STL Area, Illinois Side
    1995 Firebird
    Quote Originally Posted by weberje View Post
    Here's the pics:
    I agree on the result, very nice looking. Doesn't even look like spray paint, only question is. What kind did you use?? I'm not sure on how hot regular(if you used that) spray paint can get, or did you use high temp paint? Either way it is a very nice man.
    Looks good, what kind of prep did you do and did you clear it?
    Painted manta stripe
    weberje
    Guest
    Thanks!
    Prep'd as follows:
    Sanded up to 320 grit.
    Adhesion promoter- 2 coats.
    Duplicolor engine (500 degree) primer- 3 or 4 coats.
    Cured a day.
    Sanded to 400 grit.
    Week later:
    Duplicolor engine (500 degree) Gloss Black- 5 coats.
    Cured a day.
    Sanded to 2000 grit.
    Duplicolor engine (500 degree) Clear- 5 coats.
    Total- Took about 2 weeks to complete in my spare time.
    Am very pleased and can't wait to get it in.
    The pictures don't really do it justice.
    Feb 2007
    1995 Firebird
    Thanks!
    Prep'd as follows:
    Cured a day.
    Sanded to 400 grit.
    Week later:
    Cured a day.
    When you sanded did you use a block or by hand due to its shape??
    weberje
    Guest
    I just sanded by hand.
    rapter34
    Guest
    very nice job!
    weberje
    Guest
    I'm doing the swap tomorrow. I decided to wait until I had an oil pressure sender in reserve just in case. Had to order it as there were none available in town, so... We shall see. Any input / tips about removing the air/egr systems? All info appreciated.
  1. intake painted
    By 98camarols1 in forum Appearance Section
    Last Post: 12-21-2011, 06:22 PM
  2. Painted My LS1 Intake
    By fbodyNATION in forum External Engine
    Last Post: 07-20-2011, 02:15 PM
  3. painted LS6 intake??
    By Coydawg6 in forum Appearance Section
    Last Post: 03-21-2011, 10:36 AM
  4. My painted LS6 intake
    By DansRedZ28 in forum External Engine
    Last Post: 03-29-2006, 06:13 PM
  5. painted Intake
    By BLKbandit98 in forum Firebird / WS6
    Last Post: 01-19-2006, 07:35 PM
