Thread: Rearend
    Member Fade2Black's Avatar
    Detroit Michigan
    2000 TransAM M6
    Question Rearend
    I want to strengthen my rearend to put more power to the ground
    Help the novice out what should i do what should i get
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    12 bolt..panhard rod..torque arm...LCA's....etc
    Detroit Michigan
    2000 TransAM M6
    Where should i get that from and what brand is good quality
    No 55mph 1QuikWS6's Avatar
    USA
    2000 WS6 Trans Am
    If I understand you correctly, you are asking what you can do to strengthen the stock 10-bolt?
    About all you can do is use studs in place of the bolts for the main caps, add an aftermarket aluminum girdle style rear end cover that incorporates thrust bolts to keep the main caps from walking and possibly swap out your stock Zexel Torsen Diff (if that's what you have) for the HD version (SLP used to carry these, but I don't know if they have them available anymore) The diff swap out was one of the normal operations performed by SLP when they did their conversions.
    When I changed over from 3.42's to 3.73's I did all of the above, plus made sure to use only high quality diff bearings and axle bearings made in USA. Gears I used were also the genuine GM gears - to prevent whine - some of the aftermarket gears sets whine no matter how they are set-up. The GM gears don't have this problem (unless your installer has no idea what he's doing). I also have a Yank PY3600E verter with chromolly DS/Spicer U-Joints.
    My stock 10-bolt is still alive and well with the above mods and the #'s in my sig. However, I don't race the car regularly (at the track at least ), and have only ever ran 315/35-17 street tires = not much traction at initial WOT = not as much shock to drivetrain.
    -Jay-
    2000 Phoenix WS6 Trans Am
    Pride of Western PA Car Shows
    426RWHP/418RWTQ N/A (Mustang Dyno MD-1750)
    584RWHP/510RWTQ Massaged by TNT (Mustang Dyno MD-1750)
  1. Question: GTO rearend
    By cammed goat in forum GTO
    Last Post: 02-12-2011, 08:53 PM
  2. 9'' rearend ?????
    By sweet2000 in forum Suspension and Handling
    Last Post: 08-26-2007, 07:31 AM
  3. STS=New Rearend??
    By OnEbAdReDSS in forum Forced Induction
    Last Post: 09-03-2006, 08:43 AM
  4. Rearend help :(
    By Element187 in forum Drivetrain
    Last Post: 06-02-2006, 01:55 PM
