Results 1 to 11 of 11
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    pacesetter header banging
    im sure it's been posted before, but i can't find it..does anyone know where i can get something to stop the pacesetter headers from banging on the body during acceleration? it's really annoying
    thanks for the help
    someday joejenkinsglass's Avatar
    Iowa
    green
    98 formula
    put a block of wood under the gas pedal
    if one of your motor mounts or trans mount is worn or broken that will cause it if they arent your gonna have to get out the ford tool aka (hammer) it sucks but that is really the only way to stop it
    it's more than likely your Y-pipe that's banging and not the headers themselves. Mufflex makes a hanger that's supposed to stop it. I just adjusted my exhaust and it cured it for me. I loosened everything all the way back to clamp above the axle. Then I changed the angle a little bit of the over the axle pipe to give me as much clearance as possible. After that I wedged blocks of wood between the floor and exhaust and tightened everythig down. Lastly, knock the blocks of wood out and you're good to go.
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    Look the exhaust over really well.. as well as the underside of the car.. if they are banging/rubbing.. you will be able to tell where... then adjust from there...
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    heat up y pipe and bend downwards.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Iowa
    green
    98 formula
    my exhaust has very little adjustment but if yours does that would be great
    Arizona
    I ended up cutting and rewelding my y-pipe,,,,fixed it for me. Common problem though.
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    talking to a people with pacesetter headers say they have the same problem with them...it bangs right at the bend of the y-pipe on the drivers side there are marks where it hits..along with the BFH marks>.>
    anyway thank you for the help...might try some of that advice i like the block of wood under the pedal though that just might work
    ..if my lead foot isn't to heavy to just smash the wood into pieces
    Iowa
    green
    98 formula
    Quote Originally Posted by TmaxicanA View Post
    I kinda had the opposite problem my foot wasn't heavy enough so I just pinned the throttle open now all I have to do is turn the key
    Member fxgs's Avatar
    Camp Hill, Pa
    Onyx Black
    2002 SLP Camaro SS
    Yes they do..................part # LS1-HR.........$40.........no problems on my SS since installing it.
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    Quote Originally Posted by fxgs View Post
    thanks a bunch
  1. need help with pacesetter header and y pipe instal
    By getcha01 in forum External Engine
    Last Post: 01-01-2009, 07:17 PM
  2. Pacesetter header install
    By Rob Mellinger in forum External Engine
    Last Post: 10-25-2008, 02:30 PM
  3. Pacesetter header questions
    By andy670ho in forum External Engine
    Last Post: 03-12-2007, 06:57 AM
  4. Pacesetter header info
    By bbfirebird in forum External Engine
    Last Post: 09-30-2005, 01:57 PM
