    Member Whiteboycntdnce's Avatar
    Virginia
    2000 / SS
    Just installed new throttle Body,idle issue
    Just installed a p/p throttle body, when i went to fire the car up it was idling at like 2300, turned it off then started it back up... Idles a little lower @ 1600, whats going on? the tps and idle air control valve only go in one way so how could i have f'd that up??
    bay area
    1999 Hardtop Z28
    check all the sensors for oil/dirt
    check your intake gasket, mine was all tore back when i replaced my tb
    if it still does it, take off your tb, and hold it up to a light and see if you can see any light around the blade itself. if you can, it was over ported.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Did you check the idle screw ? Might be open to far.
    Virginia
    2000 / SS
    I actually just adjusted the line and it idles normal now. BUT I notice a "click" in the pedal just before the gas pedal hits. It's annoyingmore thananything else
    Feb 2007
    St Thomas, PA
    If you have the idle screw closed to far, the throttle plate can stick a little. You can feel it right at the TB.
  1. idle issue.. may be tune issue.. help?
    By okiels1 in forum General Help
    Last Post: 12-07-2016, 02:17 PM
  2. Help: Throttle body cable no idle
    By Tanner62193 in forum General Help
    Last Post: 04-27-2016, 03:03 AM
  3. New Throttle Body causes rough idle
    By JwMonE99 in forum External Engine
    Last Post: 07-08-2009, 08:12 PM
  4. ported throttle body new idle
    By ssmike in forum External Engine
    Last Post: 07-24-2008, 06:28 AM
  5. Ported Throttle Body and higher idle??
    By Midnight02 in forum External Engine
    Last Post: 03-23-2007, 11:21 PM
