Results 1 to 2 of 2
Thread: vats
02-07-2008, 05:10 PM #1
- Dec 2007
- texas
pewter- 2000 pontiac trans am ws-
vats
how can i get my key measurement with the ohm so i know what resistor to buy where can i go get a measurement and where can i buy a resistor.
02-08-2008, 01:19 AM #2
you can buy a multimeter from radio shack for ~$10-15 if you don't know anyone that owns one. On your key there's a little "pellet". Set the meter on ohms ( this symbol on the meter Ω ) and touch one lead to one side of your pellet and the other lead to the other side of the pellet and see what reading you get. After you get the reading see where it falls on the chart about 3/4 of the way down this page pellet chart and see what your nominal number is. Go back to radio shack if you don't have a better electrical supply place and they should have resistors that will work. I had to solder 2 in a series to hit my nominal reading but you may not have to. Either way, you want to be as close to the nominal number as possible because resistors have a variance stripe ( silver is 10% and gold is 5%) that may let it fall out of range from time to time.
Help: 3rd gen VATS
By 2000dreambird in forum General HelpReplies: 2Last Post: 08-05-2013, 10:14 PM -
Vats help!!!!
By 99WS6MAN in forum General HelpReplies: 8Last Post: 07-23-2011, 04:33 PM -
Vats
By kris6273 in forum General HelpReplies: 4Last Post: 06-26-2008, 02:27 PM -
Vats Help
By fasted in forum Stereo and ElectronicsReplies: 0Last Post: 03-04-2008, 02:48 AM -
VATS????Security problem with the VATS.
By LS1RacerMan30 in forum General HelpReplies: 14Last Post: 07-14-2007, 07:39 AM
