Results 1 to 15 of 15
    TECH Fanatic AFASTYZFR1's Avatar
    USA
    3 (100%)
    Sunset Orange
    2001 Procharged Camaro SS
    4.10 GM Gears (10 bolt)
    4.10 GM Gears for 10 bolt. Just bought a 9in so these are not needed. Teeth are in excellent shape and the gears never whined. $150 shipped obo
    01 SOM SS D-1SC Tuned by Steve: TunedByFrost.com
    FQuick Garage 764 rwhp / 645 tq
    USA
    3 (100%)
    Sunset Orange
    bump $125 shipped
    Wisconsin
    3 (100%)
    2001 Camaro SS M6
    How many miles are on them.
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    USA
    3 (100%)
    Sunset Orange
    bought car with 18k now it has 24k .......gears were in car when I bought it, so they have 24k miles or less
    USA
    3 (100%)
    Sunset Orange
    bump
    Junior Member cdorch's Avatar
    Cape Cod
    1998 Z28 M6
    are all 10-bolts the same carrier? if not, what are these for? i have a 98 m6 and may be interested if they fit
    USA
    3 (100%)
    Sunset Orange
    they should fit.....my car had a torsen diff......maybe ask some members in the gears and axle section
    Cape Cod
    1998 Z28 M6
    ok i did a search...assuming these came out of the m6 car in your sig then yes they will fit...is this everything i would need for install?
    Mobile
    1996 WS6 Formula
    If you tear the rearend down, you should really go ahead and rebearing everything while you are there. You absolutely have to re-setup the rearend, which means new pinion seal, new crush sleeve, and various pinion shims, as what is currently pressed on will more than likely not work on any other rearend. Otherwise you will have to remove your current pinion shim from your gears and place it on this pinion as that usually works out to be very close to within spec. You also have to replace the ring gear bolts as they are not to be torqued down twice. Me personally, I would buy a master install kit with shims and everything that way you know you have all parts on hand.
    My question is what gears did your rearend have originally? If they were less than 3.23 then these are the "thick" gears designed for series 2 carriers. If they were 3.23 and up, they are the standard series 3 carrier which most V8 f-bodies have.
    USA
    3 (100%)
    Sunset Orange
    This is for just the ring and pinion
    my car has the series 3 carrier....
    Member ultra_badass's Avatar
    Corpus Christi
    navy blue matallic
    2000 WS6 trans am M6
    what brand of gears
    USA
    3 (100%)
    Sunset Orange
    They are GM Gears
    USA
    3 (100%)
    Sunset Orange
    Quote Originally Posted by cdorch View Post
    Here is a link to an install kit:
    http://cgi.ebay.com/ebaymotors/10-Bo...em120222680430
    Member Sweet Chops's Avatar
    Manitowoc, WI
    1 (100%)
    Hugger Orange
    1999 Camaro Z28
    Are the gears sold?
    GRIM Z CamaroBlood's Avatar
    San Diego CA
    2001 Z28
    gears sold??
  1. 3.73 Gears 10 bolt
    By AFASTYZFR1 in forum Parts For Sale / Trade
    Last Post: 10-22-2008, 03:26 AM
  2. FS 3.42 gears for GM 10 bolt
    By mvvette97 in forum Parts For Sale / Trade
    Last Post: 08-06-2007, 01:24 PM
  3. 4:10 Gears (New) 10 Bolt. 3.08 Gears Low Miles. 12 Bolt.
    By 991lez in forum Parts For Sale / Trade
    Last Post: 04-14-2006, 01:03 PM
  4. WTB: 8.2 10-bolt gears
    By Mr. CarelessAndImprudent in forum Parts Wanted / Trade
    Last Post: 10-21-2005, 09:39 PM
