Results 1 to 10 of 10
Thread: 90mm MAF
02-04-2008, 06:56 AM #1
- May 2006
- Canada
Blue 1997 Trans Am(Sold)- Pewter 2001 Trans Am Vert
90mm MAF
I was wondering if anyone makes a screened 90 mm maf
02-04-2008, 07:05 AM #2
I don't think anyone makes a 90mm, but TSP makes a 100mm that they have just released (as of today) that's supposed to be one hell of a unit. Too bad it costs $250 or I'd have one.
02-04-2008, 08:23 AM #3
- Thornton, CO
If you aren't making over 500HP...stick with the stocker.
You will thank me later.
02-04-2008, 09:58 AM #4
- May 2006
- Canada
thats sounds like good advice Luos... I have heard a lot of nightmare stories about aftermarket mafs giving bad readings. Just doesn't seem to make sense to upgrade to 90mm throttle body, and 90mm intake... but ahead of all that you have a 78mm maf restricting it all...
02-04-2008, 10:03 AM #5
- Thornton, CO
I understand your point.
The intake distributes air into the heads though, instead of the direct flow through the MAF.
Air flows easy through the MAF location.
02-04-2008, 10:08 AM #6
- May 2006
- Canada
well I guess all I have left to ask on this matter is is a 90/90 worth the money if you're not upgrading the maf... my end all be all goal will probably be P1SC on stock displacement and hopefully 500rwhp...
02-04-2008, 10:12 AM #7
- Thornton, CO
Heard of issues with the FAST lifting off the heads with boost.
Not sure how valid that is though.
02-04-2008, 10:16 AM #8
- May 2006
- Canada
I don't see what would make a fast intake lift where as a LS6 wouldn't... perhaps just a coincidence that most guys that are putting down lots of boost and making lots of power have upgraded to a fast... or is there something about their design that I havne' heard about
02-04-2008, 10:17 AM #9
- Thornton, CO
Seems around here the ones running higher boost levels are using sheetmetal intakes. Like the Wieland.
02-04-2008, 10:31 AM #10
Wanted: F.A.S.T 90mm INTAKE AND 90mm throttle body
By spooled88monte in forum Parts Wanted / TradeReplies: 0Last Post: 02-21-2008, 02:58 PM -
New 90MM LSX Fast intake & New Nick Williams 90MM Throttle Body for LS1 $1000.00 &shp
By harnick3 in forum Parts For Sale / TradeReplies: 5Last Post: 07-30-2007, 07:23 AM -
90mm tb?
By SSee ya in forum External EngineReplies: 5Last Post: 09-09-2006, 09:51 PM -
90mm LSX or 90mm LS2 C6 Corvette intake manifold?
By waldo31031 in forum Forced InductionReplies: 4Last Post: 02-14-2006, 08:07 AM -
WTB LSX 90MM Intake and 90MM Throttle Body
By XtinKt in forum Parts Wanted / TradeReplies: 0Last Post: 01-25-2006, 01:59 PM
